Need input on box design
Username: Bernymac
Phnom PenhCambodia
Post Number: 4735
What do you guys think? 3.4cuft tuned to about 33hz after sub and port disp. You think 40sqin of port area will be sufficient. My trunk opening only allows for a box that is 30 x 15 and I don't know how deep I can go before the box hits the floor and won't allow me to slide it in any further. This is for a 15" AP Axis. With the dimensions the way they are, the sub will have to face upwards and port back or port to the side.
Username: Insearchofbass
York, Pennsylvania
Post Number: 12124
Id go with 3 4 inch aeros if you can for the port.
Username: Bernymac
Phnom PenhCambodia
Post Number: 4736
Ahhh, I forgot about aero's. Only problem is that I don't know how to calculate them...Think you can help sean?
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5825
I think this box plan is pretty damn good i would just some more port area maybe an extra 25 sq inches would be nice
Username: Bernymac
Phnom PenhCambodia
Post Number: 4738
If I make it 65sqin the port would have to be longer and it'll take up more cuft.
York, Pennsylvania
Post Number: 12125
All you need is 3 4 inch aeros 17 inches long. They will give you better air flow.
Username: Basebalz13
Moneta, Va Usa
Post Number: 1731
3 4" aero's would be perfect...thats what i used in a teammates setup for jugg 15" around the same size box but tuned slightly higher at 36 hz
Username: Bernymac
Phnom PenhCambodia
Post Number: 4741
Sounds good. If you guys couldn't read the picture above, box is gonna be roughly 30x20x15. Which gives the box 4.11cuft before sub/port disp.
York, Pennsylvania
Post Number: 12169
add more space onto that to account for sub and port displacement
