New member Username: Misiganes
Gold Coast,
QLD
Australia
Post Number: 1 Registered: Aug-09
Posted on Could someone please me help finding code for Philips RC600. It is installed into Mitsubishi Magna 1995 and I think it's original. Model: Philips RC600 Serial: PH600CY0193238 Thanks! |
Gold Member Username: Regrooster
Post Number: 1693 Registered: Aug-08
Posted on Check this Serial Number again to make sure it is correct because if it is a 1995 radio then it should be in my Philips database.....but it is not. |
Gold Coast,
QLD
Australia
Post Number: 2 Registered: Aug-09
Posted on Checked the code again and it seems to be correct.  |
Post Number: 1726 Registered: Aug-08
Posted on Sorry...if the numbers are correct then surprisingly it is not in my database. This means taking it to a Decoding Service to read/recode the memory chip using a laptop |
