Laguna radio code RN594FV8010490
Username: Liesowe
I need the code for my renault laguna with phillips radio serial # RN594FV8010490.
phillips radio model# 22Dc594/62S
Thanks
Username: Regrooster
Post Number: 1638
Try code 0370
Username: Liesowe
Thanks very much, i now remember that this is the correct code 0370 but my car display is not coming on and hence i cannot see the numbers to be able to enter the code.
Does anyone know any other way of entering the code.
Post Number: 1681
Try adding 1 to each digit as the first rotation steps it from - to 0.
So 0 3 7 0 will be 1 4 8 1 rotations
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
