Silver Member Username: Bazuka2020Post Number: 858 Registered: Oct-05 | In Canada people who have HD defination television (not HD ready) can get some channels th HD antena, I have a HD TV ready, is there a box or device which I can attach to my HD TV Ready and get those HD channels th antena, or is it possible to use the sonicview or other receivers. Thanks in advance |
Platinum Member Username: PlymouthCanada Post Number: 10634 Registered: Jan-08 | Bazuka If I well understand, your HD TV doesn't have a ATSC Tuner? You can buy a HD digital converter, look for RCA. |
Silver Member Username: BernardmiPost Number: 632 Registered: Dec-07 | You need an external ATSC tuner. No you can't use your Sonicview receiver to do that. Beware however. It might be cheaper to buy a new TV, Read this in-depth information |
Silver Member Username: ChumleyPost Number: 543 Registered: Dec-08 | something like this , maybe http://stbstreaming.com/index.php?_a=viewProd&productId=23 Most if not all hd fta stb's have an atsc tuner- the psat 9200 does and works good Also you could add tuner card to your pc , if possible http://tuners.visiontek.com/AIW/allinwonder.html |
Platinum Member Username: PlymouthCanada Post Number: 10635 Registered: Jan-08 | Bazuka You can buy a DVD recorder with ATSC tuner and use it to record your program. Look on DVD Ecoustics forum. |
Silver Member Username: Bazuka2020Post Number: 859 Registered: Oct-05 | Thanks every one, I will do some search and research, dont want to change the tv because its working fine. need a cost effective solution |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 4367 Registered: Oct-06 | Yo will need a good antenna and a digital converter box Check e-bay I bought an artec for my father in law It's working very well But not in HD Either that or subscribe to cableTV or satelitte HD ready means can display HD quality with an external tuner box |
