Amp for 2 kicker l7 12"
Username: Hockeytoker
Post Number: 36
im thinking about buying 2 kicker l7 12's at 4ohms.
these are the amps i wanna choose from
http://techronics.com/caraudio_9498_Hifonics-BXi-2610D-2600W-RMS-Brutus-BXi-Seri es-Class-D-Monoblock-Car-Audio-Amplifier.html
http://techronics.com/caraudio_8393_Hifonics-BXi2008D-1-Channel-Car-Audio-Amplif ier.html
http://techronics.com/caraudio_8477_Hifonics-BXi2608D-1-Channel-Car-Audio-Amplif ier.html
i'd be wiring them down to 1 ohms.
im thinking i should get the first one which is 2600 watt at 1ohms but i dont know if its to much power for the l7's.
the l7's are 750rms and 1500 peak power.
any suggestions help! thanks!
Username: Insearchofbass
York, Pennsylvania
Post Number: 11990
The Hifonics BXi2008D would be the right choice for those subs if they are dual 4 ohm each.
Post Number: 37
would this be any better?
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/7112098/vpcsid/0 /SFV/30046
York, Pennsylvania
Post Number: 11992
Id expect the previous one to be just as good and its cheaper. As well as a longer warranty.
Post Number: 38
would this amp perform any better then those hifonics?
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/5508874/vpcsid/0 /SFV/30046/sret/1811220192161722222528222322228321622328622922028922022722429522 4235234239228231236235234243234237
Username: Tb75947
Pa United States
Post Number: 15
JUST GET A 1000 WATT KICKER AMP. You'll pay like 1000 bucks and it will work good.
Username: Tinkbz
Norfolk, Va Usa
i have a ma audio hk802 amp for sale i have pics looks and work like new its 4400 watts this is it in the link http://www.sonicelectronix.com/item_2682_MA+Audio+HK802SX.html
York, Pennsylvania
Post Number: 12014
Stay away from ma audio and make sure to get an amp 1 ohm stable if the subs are dual 4 ohm each.
