Gold Member Username: SplmonsterAkron, OH USA Post Number: 1530 Registered: May-06 | well i need some help guys. I want to just do a single sealed 15 in my trunk but the only problem is that the max height in my trunk is 13". I wanna do a wedge enclosure but im not sure if it will work because the mounting depth of the sub i want is like 8". can anyone draw me up something quick? max dimensions would be W-38 H-13 D-28. http://www.the12volt.com/caraudio/boxcalcs.asp#wed There are two diff types on there and i thought the second one would work better for what im trying to do but any way you can get it to work is good with me. i could draw something up but i cant figure out if the mounting depth of the sub will screw it up. thanks guys Oh yea i want it to be about 2.6-2.7 before sub displacement so about 2.5 with the sub in oh yea and i want it to be upright as possible so its pointing towards the rear more than upwards. |
Silver Member Username: BoomtankRochester, NY USA Post Number: 615 Registered: Oct-06 | your best bet is to just put the sub firing upwards. Will make it much easier to make a box. 12" H x 28" W x 19" D (external) 2.8 cu^ft before displacement |
Silver Member Username: BoomtankRochester, NY USA Post Number: 616 Registered: Oct-06 | or try a 3.5cu^ft ported 32Hz 13" H x 38" W x 18.5" D Let me know what subwoofer your using and I could design you a box ( sealed or ported ) and/or build you one. |
Bronze Member Username: Arsenault_denisPost Number: 22 Registered: Dec-04 | I gotta ask. what program are you using? I'm on Autocad all day every day but it doesn't look like that |
Gold Member Username: Dustin3D&L Audio Tech.Dustin Post Number: 5035 Registered: Oct-05 | its called google sketchup. you can download it for free |
Silver Member Username: BoomtankRochester, NY USA Post Number: 617 Registered: Oct-06 | very nice program once you get the hang of it. |
Gold Member Username: SplmonsterAkron, OH USA Post Number: 1538 Registered: May-06 | decided to go with a ported 12 because i couldnt fit the 15 but thanks anyways man /thread |
