Username: Hockeytoker Post Number: 34 Registered: Jul-09
Thursday, August 13, 2009 - 02:34 GMT i might buy two 12" kicker l7 and was wondering what amp would be good for them thats under $400? also should i get the dual 4ohms and wire them down to 1 ohms or dual 2 ohms? thanks!!!
Username: Cal1089 Post Number: 48 Registered: Jul-09
Thursday, August 13, 2009 - 03:23 GMT well all i can say is getting max power at one ohm would be cheaper then trying to get max power at 2 ohm what is the rms of these subs anyways?
Username: Nyyfan13 Northern VA
Post Number: 11553 Registered: Jul-06
Thursday, August 13, 2009 - 03:28 GMT First off, don't buy the L7s unless you want cheap SPL. If that's the case, then good decision. If you care two sh1ts about sq, then look else where. What's your budget for this system? What car? Whats your goal for the system? Music you listen to? Room you have to work with? Size of speakers preferred and number?
Username: Hockeytoker Post Number: 35 Registered: Jul-09
Thursday, August 13, 2009 - 04:43 GMT im just looking for subs that bump hard that cost around 200 hundred a sub. i dont care about sq. toyota camry and im puttin the subs in the trunk so not to much room to work with. my budget is probably 1000 or under. i listen to rap. 12 inch subs cause 15 wont fit in my trunk and the rms for these are 750
