New member Username: AnelaAB Canada Post Number: 1 Registered: Aug-09 | Hi there, my father just purchased the K BOX "the prodigy" reciever, and im not quite sure what to do with it at all.. can anyone give me a quick step by step instruction on where to start.. and how this works.. please it would be greatlyy aprecciated.. thankss ! ! ! |
Silver Member Username: JaysonPost Number: 357 Registered: Aug-06 | by sada.. c&p is perfectablly legal lol with username don't forget to share, what is k1plus definately one member asked this question..} Ans: dah.. its a iks fta reciever what is difference b.w k1plus and nfusion feature wise..}} well k1plus is better.. if u look at few things.. it has pvr, + option of standalone ( i mean with these nagra 3 channels u have to use iks) but once nagra 3 is crack, then will allow standalone bin, so u don't have to use iks all the time, nfusion have lack of usb/pvr, so for hd u have to spend 400-500 , also pic quality is better on k1plus, i know its improved on solaris model but i haven't checked it out.. so vittu nfsuion will get those channels likely but i think it will create them for a demand of pvr model within $ 200 budget.. also it will take some load from nfusion server once people swith to k1plus lol.. it is always good to have competition, what is best place to buy k1plus/pro}} check transat electronics, list of official dealers are listed at at rookie u can't talk about bev.. how to setup k1plus/pro)} exclusive guide c&p from ftabins. SmokinChronic SmokinChronic is offline VIP Member Join Date: Dec 2008 Location: 420 Lid Lane Posts: 132 Rep Points: 57 SmokinChronic is becoming popular Default New KBOX PROdigy and KHUB Setup Guide PROdigy and KHUB setup Okay this guide is meant to address the setup of a KBox PROdigy along with the BLACK khub with the KHub logo on it. This guide is NOT applicable to the OLDER silver KHubs. 1. Connect the KBox to the coax, and power up; 2. Load the UNZIPPED bin 2.01, (or later as they are released), onto your USB; 3. Insert the USB into the port; 4. When the explorer screen appears use the remote arrow buttons to highlight the bin; 5. Press OK 6. When the bin is done loading the KBox will reboot itself; 7. Setup and scan your satellites in the menu installation dish settings menu; 8. Go to menu installation options and change Stand alone to network; 9. Set ALL AU in the same screen to OFF. 10. Plug the ethernet cable into the port on the khub; 11. Plug the KHub DIRECTLY into the KBox serial port, (NO cables needed); 12. Load the UNZIPPED khub.rom file, (found in the khub activation v2.0 in the files forum), onto your USB; 13. Insert the USB into the KBox, highlight the KHUB file on the screen; 14. Push OK; 15. When the file has loaded remove the USB from KBox; 16. Using the switch on the rear of the KBOX, reboot the KBox. Tune to an ACTIVE NAG 3 channel, (CNN 200), is a safe one. Then wait a couple of minutes and TV should begin to pla how to fix error, if something goes wrong with ur rec u will see h1 in front of ur rec..} kenmoresp's Avatar kenmoresp kenmoresp is offline Super Moderator Join Date: Nov 2007 Location: Next door to Chuck, Beverly and David Posts: 12,546 Rep Points: 9093 kenmoresp is Godlikekenmoresp is Godlikekenmoresp is Godlikekenmoresp is Godlikekenmoresp is Godlikekenmoresp is Godlikekenmoresp is Godlikekenmoresp is Godlikekenmoresp is Godlikekenmoresp is Godlikekenmoresp is Godlike Default KBox Plus - How to Fix the H1 Error on the Kbox Plus 1.) Down load factory file and K1 Plus loader and unzip the following. Link for Factory File: KBox K1 Plus v1.71 Factory Bin Beta Link for Factory Loader: KBox Loader V2.00 - FTABins.NET Edition 2.) Connect RS232 cable to the receiver and plug the power cord from the receiver into the wall with the main power source off on the receiver. 3.) Open the loader on your desk top. Locate the factory file with the browse button on the loader. 4.) Now have your finger on the rear power button. Click it to the on position. When you see the H1 error appear on the display. Click CONNECT on the loader immediately. This may take a few tries but the receiver will eventually accept the file. 5.) Load the latest file and reconnect the receiver back up to the your t.v. 6.) Enter all your dish settings and your good to go. __________________ !!KENMO!! how to download a file on pro/plus model Default KBox PROdigy - How-To Easily Load a New File 1. Download latest file and unzip it 2. download unzipped file to your usb stick 3. insert usb stick in your receiver 4. from your remote select Menu 5. in the menu screen select utilities 6. in the utilities screen select data transfer 7. you will now see your file file on the screen,if that is correct file hit ok 8. the file will start downloading Do not turn turn receiver off or remove usb stick until file has finished downloading. 9. once file has finished downloading,remove usb stick. 10. now turn receiver off and on from the back (hard reboot) 11. make sure auto roll is on 12. leave receiver on any one channel until picture comes up __________________ what is difference b.w pro vs plus both are supported equally and have same specs, plus is older and cheaper pro is brand new and little bit higher price than plus |
Bronze Member Username: TulipePost Number: 85 Registered: Jun-09 | TOO MUCH INFORMATION THAT THE GUY DONT DESERVE / SIMPLY BECUZ HE IS A LYING SON OF BITCHHHHHHHHHHHH. YOU DONT BUY THINGS THAT YOU DONT KNOW WHAT TO DO WITH IT . AND THIS FATHER HAD NO FUCKKKKKKKKING IDEA ABOUT THE BOX , JUST WAS WALKING ON THEN HE SAW GREAT COLOR OF BOX AND DECIDED TO BUY IT . JUST ASK STRIGHT QUESTION . LIKE IM STUPID AND LAZY TO READ. |
Bronze Member Username: TulipePost Number: 86 Registered: Jun-09 | ALSO U ARE A FAGGGG YOU ARE NOT A GIRL . U JUST USE GORL NAME TO HAVE SOME FUCKKKKKKING SYMPATIE |
Platinum Member Username: NydasPost Number: 15811 Registered: Jun-06 | Anela Bella: Ignore the last two posts by an ignorant maniac. Sada is the authority at this site of Kbox, and he is on holiday. jayson has given good instructions. |
Platinum Member Username: NydasPost Number: 15812 Registered: Jun-06 | James Johnaenel is also a very good authority. Read his response at: https://www.ecoustics.com/electronics/forum/home-video/585266.html |
Silver Member Username: Plymouth_glasserPost Number: 101 Registered: Apr-09 | Hey, Tulipe be nice man no way to reat a lady. ![]() |
Platinum Member Username: NydasPost Number: 15815 Registered: Jun-06 | Seymore Butts is another harraser in this forum. |
Silver Member Username: Plymouth_glasserPost Number: 103 Registered: Apr-09 | Nalin Nyda----that is why no one here can stomach you . Why are you bad mouthing me? I was talking to my good friend Tulipe Don't you like pretty girls? Picture of Mona Lisa, the lady with the pretty smile. OK. so here she is with her clothes on. ![]() BTW---Did you mean: harasser |
