Help with subwoofer amp/ wiring
Username: Cal1089
Post Number: 40
ok i have a chance to snag up a pair of JL W6's for 300 bucks. i would like to know if the audioque 1200d will power these enough at 1 ohm (is this possible). if not what amp will i need.
Username: Cal1089
Post Number: 41
never mind i have figured it out but i have a dumb question? if the amp is a 1200 watt rms. and i hook it up at 1 ohm to two subs, how much power will each sub have.
would it be the 1200 each
or 600 each
just curious sorry if its a dumb question.
does the power cut in half everytime you add a sub
Username: Ridicbass07060
Sonances wangin
Post Number: 162
600 each... no question is a dumb question when your learning
Username: Cal1089
Post Number: 42
ok that is what i figured thanks
