Security Code for my Radio!
Username: Philipquach
I have a 2002 HONDA ACCORD CRV ODYSSEY 6 DISK CD PLAYER RADIO.
Thats all information i know about it. Please help me!
nvm i've found the code 14324 if this is the correct one.
Username: Regrooster
Post Number: 1569
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any othermake.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service.
