New member Username: DrekoOttawa, Ontario Canada Post Number: 1 Registered: Aug-09 | Hi, can somebody send me the code for my radio in 1995 Honda del sol, Radio serial No : E50533788C Thank You in advance. |
Gold Member Username: RegroosterPost Number: 1577 Registered: Aug-08 | ============================================= HONDA RADIOS.................IMPORTANT NOTICE PLEASE READ BEFORE POSTING ANY CODE REQUEST ============================================= Please note: The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy HONDA radios are made by the following manufacturers ALPINE AUTOSOUND BLAUPUNKT CLARION KENWOOD MATSUSHITA PIONEER The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by BLAUPUNKT. These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing UNFORTUNATELY ... NO OTHERS ! So you will be wasting your time posting code requests here for any othermake. BLAUPUNKTS ONLY with a BP Serial Number ================================================= For EVERY other HONDA radio made by one of the other manufacturers then visit the website below https://radio-navicode.honda.com If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service. |
