Bronze Member Username: JonebgoodPost Number: 16 Registered: Dec-05 | Need help to purchase new box. Nfusion or SV 800HD. I am a road traveler and have no internet access other than wifi. What do I need for these boxes, and witch is the better of the 2. |
Platinum Member Username: PlymouthCanada Post Number: 10498 Registered: Jan-08 | JonEBgood If you want Bev, NFusion is better, for DN both are good but less freeze on NFusion. NFusion Nuvenio is MPEG-4 SD ready, none for Sonicview. For get Wi-Fi you will buy a router then hook the receiver in. ![]() |
New member Username: PaulrinPost Number: 2 Registered: May-09 | nFusion has been having tons of freezing lately though. I was trying to decide between nfusion phoenix or kbox. |
Platinum Member Username: PlymouthCanada Post Number: 10499 Registered: Jan-08 | Paul NFusion still best with less freezing than other boxes and many more channels up. ![]() |
Silver Member Username: PeggPost Number: 113 Registered: Aug-06 | What HD channels are up on nfusion on echo 61.5 and 110W? |
Platinum Member Username: PlymouthCanada Post Number: 10500 Registered: Jan-08 | Here is the list: http://spreadsheets.google.com/ccc?key=rOE1tOiUP_lPLrP25QfX1sg&pref=1 ![]() |
Bronze Member Username: JonebgoodPost Number: 17 Registered: Dec-05 | Need help to purchase new box. Nfusion or SV 8000HD. I am a road traveler and if I go to a broadband internet access what do I need to get these to go? Is there one box that works on broadband better and easier that the other? |
Platinum Member Username: PlymouthCanada Post Number: 10501 Registered: Jan-08 | JonEBgood If you want Bev, NFusion is better, for DN both are good but less freeze on NFusion. NFusion Nuvenio is MPEG-4 SD ready, none for Sonicview. For get Wi-Fi you will buy a router then hook the receiver in. You can use your laptop like a bridge and hook your receiver in if you have a Ethernet port. |
Silver Member Username: ChumleyPost Number: 512 Registered: Dec-08 | The SonicView 8000 supports MPEG4, thanks to the STi7100 Chip. The STi7100 is a new generation, high-definition set-top box decoder chip, and provides very high performance for low-cost HD systems. With enhanced performances over the STi7710, it includes an H.264/AVC/MPEG4 decoder. |
Platinum Member Username: PlymouthCanada Post Number: 10502 Registered: Jan-08 | Chumley A link please? |
