Amp for 2 CVX 12s on stock electrical?
Username: Simple_smith
Lapeer, Michigan United States
Post Number: 25
What is a good amp that would push 2 CVX 12s? The CVXs are 2 Ohm DVC with 750watt rms. Hoping to get around 1500-2000watts for less than $300. Thanks in advance.
Username: Poprocks
Post Number: 204
new or used?
Post Number: 26
New if possible
Username: Sanni
Waukegan, Illinois U.s.a
Post Number: 12
brutus 2000
Username: Drant19
DUB-C, TX
Post Number: 1748
thats gonna be real hard to do with the budget...
find a used kicker zx1500
Username: Insearchofbass
Post Number: 11584
two mb quart dsc 1000.1's (one for each sub)
http://cgi.ebay.com/MB-QUART-DSC1000-1-MONO-SUBWOOFER-AMPLIFIER-2000-WATT_W0QQit emZ270378058727QQcmdZViewItemQQptZCar_Amplifiers?hash=item3ef3c9c3e7&_trksid=p32 86.c0.m14&_trkparms=65%3A15|66%3A2|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Post Number: 11585
youll just get away with one of these amps with stock electrical....no way youll get away with 2
You could set each amp up to put out say 500 - 600 rms each until you can upgrade your electrical.
Post Number: 68
Ok i've upped the budget to $500 and I am going to be running 0ga. a kinetiks battery and a RF capacitor (got it real cheap). I will be getting a HO alternator soon.
New suggestions?
and should it be running at 2 ohms or .5 ohm for daily? I'm assuming 2 because most amps that i've seen aren't stable at .5 daily and are way expensive
York, Pennsylvania
Post Number: 11920
Two ohms. I have a mtx 81000d for sale that will put out 1500 at 2 ohms. Im asking 250 shipped for it. If your interested let me know here.
https://www.ecoustics.com/electronics/forum/car-audio/583548.html
