New member Username: Fanning49Post Number: 1 Registered: Aug-09 | I have a Crysler Sebring convertible with the Infinity stereo system with the separate amp located under the passenger seat. I am replacing the system with a new deck that has a built-in amp. I have it installed, but now need to by-pass the amp. First, is this possible? Second, how do I splice the wires? |
New member Username: ProfessorbaseTX USA Post Number: 2 Registered: Aug-09 | Not sure of your year of Sebring, but you should be able to just splice the wires from the output of your factory amp up to your new head unit's output.. after removing the factory amp. Here's a wiring code for the 2001 Sebring. Car Radio Constant 12v+ Wire: Red Car Radio Switched 12v+ Wire: Red/White Car Radio Ground Wire: Strap or Chassis Car Radio Illumination Wire: Black/Yellow Car Stereo Dimmer Wire: Black/Green Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: If equipped, the amplifier is located in the trunk (inside the left panel). Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Green Left Front Speaker Negative Wire (-): Green/Yellow Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Blue/Red Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Brown/Yellow Right Rear Speaker Positive Wire (+): Blue/Red Right Rear Speaker Negative Wire (-): Blue/White here's the link to the site...to find your year. http://www.modifiedlife.com/2001-chrysler-sebring-convertible-car-stereo-radio-w iring-diagram/ |
New member Username: Fanning49Post Number: 2 Registered: Aug-09 | Thanks, Gary. It is a 1998 Sebring Convertible. I checked out the sight you reference, but I am still puzzled. The amp is/was located under the passenger seat. It has 2 plugs going into it. Here is the info on the plugs and wires: Small Plug (11 wires) Main Color/Stripe White Red White Black Tan Black Tan Red Brown Red Green None Blue Red Purple None Green Red Red White Yellow Black Big Plug (14 wires) Main Color/Stripe Pink None Black Blue Blue Orange Blue White Brown Blue Brown Yellow Orange None Orange Brown Yellow Red Yellow Black Blue Purple Blue Green Green Purple Green Light Green Any suggestions on what I need to do? Thanks. |
New member Username: ProfessorbaseTX USA Post Number: 8 Registered: Aug-09 | I googled around to try to find a matching wiring code for the 1998 model, but some wires don't match up. |
