Username: Splguy1989 Post Number: 2 Registered: Aug-09
Wednesday, August 05, 2009 - 00:40 GMT i have 2 type r 12's, and i heard a friends older style punch hx2 12's, 4 in a tundra ext cab, walled and DAMN i that was very loud. he said if i trade my type r's for T1's that ill get a lil louder, are they really louder?
Username: Jakeyplaysbass St. Louis,
MO / ASU
Post Number: 3715 Registered: Jul-05
Wednesday, August 05, 2009 - 00:46 GMT 2 Type R 12s... for... 1 T1 12? No you will not get louder at all.
MO / ASU
Post Number: 3716 Registered: Jul-05
Wednesday, August 05, 2009 - 00:49 GMT Whoops didnt read that right... I would keep the type Rs.. if your looking to get louder theres other options that will work better. 1. Change the box 2. Add more type Rs 3. Upgrade to 15"s or 18"s 4. Add more power You could also do a combo and get way louder... example do 2 15s and double your power.
Username: Drant19 DUB-C,
TX
Post Number: 1889 Registered: Aug-07
Wednesday, August 05, 2009 - 02:03 GMT whats your current box and amp set up?? also what vehicle do you have?
Username: Splguy1989 Post Number: 3 Registered: Aug-09
Wednesday, August 05, 2009 - 03:37 GMT i have a PYLE (of sh!t) 1200rms lol, its prob only have 600-800rms, but i have a post about the mtx jh1200, in the amp section box is 5cu after sub and port displacement @ 36hz car is olds alero 99
TX
Post Number: 1892 Registered: Aug-07
Wednesday, August 05, 2009 - 04:09 GMT i have always liked the type-r, so i would stick with the ARRRs...that may be a bit big of a box for them but not by much, thats fine... i definately would find an amp that does >1200rms. AQ 1200d comes to mind Sundown SAE1200 or SAZ1500 RD 1000.1 or 1750.1 Massive Audio 1500.1 theres lots of options when it comes to 1200-1500rms @ 1ohm definately upgrade that amp to something of quality and you will notice a difference
Username: Jd93kid Brandon,
MS
U.S.
Post Number: 67 Registered: Jul-09
Wednesday, August 05, 2009 - 04:23 GMT yeah I like the type r's also.. Stick with them.
Username: Splguy1989 Post Number: 4 Registered: Aug-09
Wednesday, August 05, 2009 - 04:28 GMT thanks for your help every1, i may get the saz1500, when i get paid friday, i love sundown i would be able to tell a difference with that amp right? even a little to the ear
Username: Rovin 1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 15307 Registered: Jul-05
Wednesday, August 05, 2009 - 04:31 GMT Rs are really good for the $ but u need more power id give each a clean 600wrms but those old school Hx2 r damn good subs as well ...i think a pair of those cud even beat a pair of R in both quality lows & output ...
Username: Splguy1989 Post Number: 5 Registered: Aug-09
Wednesday, August 05, 2009 - 05:09 GMT yea man, he show me the lows that would take your breath completely away, and high end ground shaking bass, literally shakin tha groung i love the old school's lol , but i heard the T1 and T2, aint as good as the punch hx2 and power hx2
MO / ASU
Post Number: 3718 Registered: Jul-05
Wednesday, August 05, 2009 - 05:35 GMT Power hx2s were sick. There was a monster truck, literally, that was local and had 6 15s walled. Different to say the least. I don't care for any of RFs new stuff, but their T series amps do rated power + which is good.
Username: Ducka Houghton and/or Macomb,
MI
United States
Post Number: 1121 Registered: Jan-08
Wednesday, August 05, 2009 - 05:56 GMT I have the same car and same subs. Make the box subs and port facing into the cabin close as possible to the back seats, then block off all gaps between the box and trunk. Get a nice amp like the saz1500 and you should be pretty loud.
Username: Splguy1989 Post Number: 6 Registered: Aug-09
Wednesday, August 05, 2009 - 06:15 GMT ill turn them to seat, thanks kevin
Username: Cal1089 Post Number: 30 Registered: Jul-09
Wednesday, August 05, 2009 - 13:33 GMT i had the pyle it was more like 200 true rms u will be surprised and very happy with new amp!
Username: Cal1089 Post Number: 31 Registered: Jul-09
Wednesday, August 05, 2009 - 15:04 GMT i had the pyle it was more like 200 true rms u will be surprised and very happy with new amp!
