Need advice for sub in 2001 Toyota Tundra
Username: Mtoyama
so im getting a system for my tundra and i was informed that i was going to need to purchase a slim sub that would have to go on the floor in the back of the extended cab or on one of the seats. the cab is already small as it is and with a sub on the floor it would make it that much smaller. is there any slim sub that could fit under the front seats? or does anyone know if it would be possible to fit two 8' subs in the center console if i were to remove it? thanks a bunch.
Username: Bernymac
Phnom PenhCambodia
Post Number: 4705
This is what I did for my dads truck. Single 12" fi ssd ported. I don't know the amount of cuft and whats its tuned to but it sounds really good.
Username: Afroopuff
Post Number: 511
Berny... stupid question man... but where did you end up putting the sub? Haha
Did you flip it and carpet it to make it look like a center console? if so it looks really slick
Username: Bernymac
Phnom PenhCambodia
Post Number: 4710
Sub is under the box facing the floor.
Username: Drant19
DUB-C, TX
Post Number: 1877
does the box sit on risers or something berny??
Username: Bernymac
Phnom PenhCambodia
Post Number: 4711
yeah it has legs in the back.
Username: Drant19
DUB-C, TX
Post Number: 1879
schweet bern! looks really clean
