Need Help With 4 X 1 switch
Username: Prado123
Post Number: 11
Guys i have these two switches but the problem is only port 1 and 3 and working at a time...when i connect 2 and 4 its totally dead so please tell me which switch u all have .............
I m having problem when i need to watch international channels i need to switch wires again and again......becuase 2 ports are dead
SO i m looking all 4 ports working swtich pls help me and post switch photo thanks
Username: Doa
Post Number: 66
You need to have the ports assigned properly in the setup menu of your reciever(s).
Username: Prado123
Post Number: 12
i have checked and assigned everything right way..but no luck
Username: Plymouth
Post Number: 10349
Prado
The switch on first picture only work 4 days for me, this a crap.
Buy a heavy duty outdoor switch.
Username: Prado123
Post Number: 13
in both switches 2 prts are dead..i dont know y
i think voltage burn 2 ports i guess.
Username: Mahashweta
Post Number: 12
prado both switches are good.
I have used both of them with no problem.
the Chieta is the better of the two.
When you install a DiSEqC Switch or change ports
you must turn off your receiver first.
If your receiver is on when you change from
one port to other you may be touching ground
and shorting out that port.
Expose to the weather will also damage the switch.
Post Number: 13
prado are they the same ports on both switches?
If they are then you will need to replace the 2 wires from the LNB to the switch.
Username: Plymouth
Post Number: 10352
I never turned off my receiver before unhook the switch and never blowed a switch, always the switches burn by itself.
Username: Plymouth
Post Number: 10361
Joker are you ga/y?
Because you always post ga/y pictures.
Username: Plymouth
Post Number: 10362
Gregraf post much better pictures you
Username: Plymouth
Post Number: 10364
Yes
I like Italien salami but it seems that you like pen1s
Username: Topy
Post Number: 105
Prado,,, I had hard time with all these switches, then I get rid of all these, Buy a EMP Century switch, before buy I will give u a tip with first swtich, change your diseq setting from 2.0 to 1.1, u will see port can be recogise, the big question is that which receiver u r using? I had same problem with Kbox when I change switch setting from 2.0 to 1.1 bam it worked , try & post the result if failed post the sat info, receiver name & setting. we all will try to fix. thx
