71" samsung DLP picture problems
Username: Clubin11
hey guys im having a problem with my dlp model number hlr7178w its an awsome tv but right now its acting up my problem is that the picture is breaking up or distorting and sometimes only being 8 inches across the top of the screen and then wen the picture goes out i cant even access menu at all nothing can be seen so i took the access peice of took the lamp out for a few looked around put back in and it works for like 2 hours then starts to do it
Username: Clubin11
that is the screen that i get when its done flikering and scrambleing during that screen u cannot access menu nothing u cannot see nothing but that
[IMG]http://i579.photobucket.com/albums/ss234/tedbrown78/tv.jpg[/IMG]
Username: Clubin11
thanks for all the help guys
Username: Tvtroublesolution
San Diego, California USA
Post Number: 21
Hi Ted,
Bring up your menu screen when the picture goes crazy, if it doesn't come on or if it looks distorted then this might be a problem with your DMD; also check all your inputs, try your DVD to see if you have the same problem, if not then this could be an issue with your analog or digital board
Good luck Ted
