New member Username: FmasPost Number: 1 Registered: Jun-09 | Hope someone can help me out. Read alot of these and wanted to see if I can pinpoint which board I need to get, digital or analog. I get the green on most everything except in the PIP or when I am playing a DVD. The pic is clear then. Also, have the green screen when no cables are attached to tv. Don't have a HDMI cable so I can't check with laptop. Menus come up fine. I did the test with mute, 8,1,2, and power and ran test on both. Nothing came back as error. Is there another test to check to see which board it is? I am sure DMD board is good. I just have the green checkerboard pattern on those inputs. Any advice would be appreciated. |
Bronze Member Username: TvtroublesolutionSan Diego, California USA Post Number: 24 Registered: Jun-09 | Hi Fred, It seems your analog board may be the one with the problem, basically the signal passes through the analog board, then through the digital and finally through the DMD. Because your DVD runs OK, I think the problem is on the analog signal input. This link will show you more similar symptoms, check it out: https://www.ecoustics.com/electronics/forum/home-video/555766.html Good Luck |
