Silver Member Username: Frobi
Post Number: 392 Registered: Aug-06
Posted on Is Nova working on any satellite? |
Platinum Member Username: Plymouth
Post Number: 10241 Registered: Jan-08
Posted on neil List the satellites you want get. It work on all FTA satellites, all Bev and few DN, not work on Globecast PTA.
Post Number: 393 Registered: Aug-06
Posted on I want 118 for international and PPV on 110 What file for Nfusion Nova? Thanks Plymouth. |
Bronze Member Username: Terebichan
Post Number: 64 Registered: Nov-08
Posted on neil Nova is up on some BEV channels FEW french and will be not supported after 31 august. |
Post Number: 10255 Registered: Jan-08
Posted on neil There is 2 files for Nova one for clone and one for real.
http://currentbins.com/ftafiles/
Silver Member Username: Mohamad_obama
Terhan,
Iran
Iran
Post Number: 464 Registered: Oct-08
Posted on It will work on 91.................................for now and true fta |
Silver Member Username: Imars99
Post Number: 270 Registered: Aug-06
Posted on It work on 81, 91 and true fta. |
Silver Member Username: Bluebee
Post Number: 120 Registered: May-06
Posted on Deosn't work on Bev, 82. "No or Bad Signal". But if I check the Signal Quality from the menu, its above 80%. |
Post Number: 10273 Registered: Jan-08
Posted on Blue 82W is spot beam for Canada only, If you live on Canada border, you can get it, but in South USA forget it.
