What ohms?
Username: Cal1089
Post Number: 33
i am looking to get audioque subs need to know if i where to get a single subwoofer what sub on here would i need for the audioque1200d to run at one ohm
same with the sd2.5 if i got two can i run at one ohm?
can i run the hdc3 18 by it self at one ohm?
Username: Ducka
Houghton and/or Macomb, MI United States
Post Number: 1125
If you want 2 subs get 4ohmdvc. If you want one get 2ohm dvc.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
Username: Cal1089
Post Number: 34
WOULD THE HDC 18 D2 WORK FOR ONE OHM ON THE AQ1200D
AND HOW ABOUT A PAIR 15SD2.5 D4 AT ONE OHM ON THIS AMP?
AND WHAT SETUP OUTTA THESE TWO DO YOU THINK WOULD HAVE THE MOST SPL/ DB IN A 1994 JEEP GRAND CHEROKEE.
Username: Ducka
Post Number: 1127
YES BOTH OF THOSE WOULD WORK... LIKE I SAID BEFORE.
IMO THE 2 15"D2.5'S WOULD BE LOUDER, BUT IT ALL DEPENDS ON INSTALL.
Username: Big_edge_head
Milwaukee, WI
Post Number: 3995
Caleb, take a look at the link posted above. You enter the voice coil config and the number of subs and it will tell you your wiring options.
Username: Cal1089
Post Number: 35
im sorry people :-( thanks for the help
Username: Drant19
DUB-C, TX
Post Number: 1897
LOL @ Ducka!
caleb,
i would be hard pressed to see the 18" be louder on the same power as 2 15s.. i would def go with the 15s if you want more SPL!
i hope you are ready to give up all of the storage space tho.
