2 amps or 1??
Username: Sgreer
Hi. I am going to run 4 infinity kappas and a 12" Kicker.
Would it be better to buy one amp for the speakers and one for the sub, or buy one 5 channel amp for everything?
Username: Domenico
Glendale, AZ USA
Post Number: 87
Get one multi chnl amp for the kappas.
Get on mono amp for the kicker.
For the kicker make sure you get a custom box.. will sound so much better.
Username: Domenico
Glendale, AZ USA
Post Number: 88
also, if you need help with picking out an amp ill be more then happy to help
Username: Sgreer
ok well thank you so much. its nice to finally get a response from someone lol.
My Kappas are 75w RMS so Im going to get a Alpine MRP-f300 for those.
And for my sub which is a 12" Kicker that runs at 400 RMS at 2 ohm I am either getting the Alpine MRP-m500 or a Kicker zx400.1. I am leaning towards the Kicker because it has a bass control remote.
What do you think?
Username: Bonhamd
Traverse City, MI
Post Number: 1956
dont do that
you do not want to run different subs
what infinity subs do you have (model # and voice coil config)
Username: Insearchofbass
York, Pennsylvania
Post Number: 12670
Hes only running one sub.
Username: Sgreer
iv got 4 Infinity Kappa speakers and 1 Kicker sub
Which amp is better for the 400w RMS Kicker sub. It will be ran at 2 ohm. Should i get the zx400.1 (400 x1) or a Alpine mrp-m500 (500 x 1)?
Username: Bonhamd
Traverse City, MI
Post Number: 1957
ahh i see. my bad.
i thought you had 4 kappa subs and 1 kicker sub
Username: Sgreer
Post Number: 7
its ok, I was unclear in describing it.
Can anyone give me a suggestion between the Kicker and Alpine amps for the sub?
Username: Bonhamd
Traverse City, MI
Post Number: 1958
both great options for amps
what is your budget for both amps
Username: Sgreer
Post Number: 8
well i can get either one for around 150 new.
i have another question if you dont mind...
if my speakers and sub are both made to be ran at 2 ohm (the speakers and amp dont even have a power rating for 4 ohm), do i have to wire them a certain way or just hook everything up and it will automaticly be running at 2 ohm?
