Username: Getmo96 Post Number: 141 Registered: Jul-08
Wednesday, July 15, 2009 - 00:18 GMT I know i have seen some instructions but where are they. I got a new box, what are the steps i need to take to set it up? Thanks.
Username: Getmo96 Post Number: 144 Registered: Jul-08
Wednesday, July 15, 2009 - 01:28 GMT ethermet connect directly to my verizon router entered the DNS 4.2.2.2 and 4.2.2.1 on router router sees it, named "DevilPotEFDA88" red light on khub network settings > dhcp > push download > box asks 1.62 detected download it? I say yes, it fails. I say no, it says Module not connected.
Username: Pegg Post Number: 103 Registered: Aug-06
Wednesday, July 15, 2009 - 02:11 GMT your have to download 201 file first and then khub ROM file. Both through usb
Username: Leonard15 Post Number: 91 Registered: Oct-05
Wednesday, July 15, 2009 - 02:29 GMT Can you plug the receiver directly to a computer that is linked wirelessly to your router or does that receiver have to be connected to the router?
Username: Getmo96 Post Number: 147 Registered: Jul-08
Wednesday, July 15, 2009 - 02:34 GMT Does the khub.rom file have to be loaded directly to the khub or is there a back door. I did not receive a power supply for it. I have the tools to make one but do not know the voltage.
Username: Getmo96 Post Number: 148 Registered: Jul-08
Wednesday, July 15, 2009 - 02:41 GMT I built one for 3v and it works. The instructions i found said to use FT_a1.1.25_uo(p).rom . What is the other file in the kit named FT_v1.25_up(f).rom for?
