SV8000 ihub 129
Username: Tirijo
Post Number: 101
ok, got a SV8000, Ihub, latest bin and firmware...have an old school dish 1000...get 110 and 119 in great...but when it comes to 129, i get one tp 12516 and 73 strength a dn 93 quality...everything else is either 0 strenght and 0 quality or 70 strength 0 quality...anyways...had it set up like before i went to the ihub...into 4x1 diseqc with 119 = 1 110 = 2 and 129 =3 ... well then i went out to the dish ran a 5 ft coax from the 129 lnb direct into the dish ... first time i turned it on...i got full strength and quality on all the expected tps, well i figured either i have a bad connection along the line, or too much coax ... but unfortuneatly, everytime i do anything with the power on the SV8000, i lose all strength and quality and have to do a factory reset ... again, this started after the ihub software...well, any suggestions...should i wipe the box clean and start over? thanks in advance
