NEED TO BUY 1000 watt amp
Username: Frost42069
I need an amp that is 1000 rms at 2 ohms. Not much concerned on brands except planning on staying away from pyle.
Username: Poprocks
Post Number: 264
Budget?
New or Used?
update lol it can be at 1ohm if the amp is 1ohm stable....looking in the 200 shipped range...it would be nice if it was slightly over 1000 watts though bc i'm trying to push a 15" Kicker l7 or a 15" Fi Q
Username: Poprocks
Post Number: 266
http://www.caraudioclassifieds.org/forum/showthread.php?t=11764&page=2
Go with the Q over the L7
Some dude my brother knows has a Fi Q 15" on a Sundown SAE-1200D.(4cf.net@32Hz)
Low and loud.
Username: Insearchofbass
York, Pennsylvania
Post Number: 11799
Audioque 1200.1 for the amp. (1 ohm stable) 249 shipped.
http://www.audioque.com/aq/order.htm
Username: Tb75947
Pa United States
Personally I would go with Mobile Spec. You'll only spend like 300 bucks on an amp with 900w rms and it will run at 1, 2 or 4 ohms, they're good amps
