Gold Member Username: Canada_havanaCanada Post Number: 2032 Registered: Sep-07 | tomado de otra page,,, tratenlo a su propio riesgo,,, y posten informacion,,,,,, Member Join Date: Aug 2007 Posts: 1,270 Confirmed 177 CN working..chirp method VS ULTRA -------------------------------------------------------------------------------- Confirmed 177 CN working..chirp method VS ULTRA confirmed by me. Confirmed 177 CN working..chirp method VS ULTRA VS ULTRA Delete all channels by going to: Menu and selecting: Edit channels: Right arrow to select delete: and hit f3 to delete all channels. exit and save Now goto Channel Scan Satellite ( Pick ********110*) Network Search (OFF) Scroll down to edit transponders Hit F3 button on remote & DELETE ALL TRANSPONDERS After deleting hit F1 on remote to add user transponder. Freq = 12486,S/R = 20000,Pol = V,FEC = 5/6,TV & Radio will be zero because I'ts not saved yet. NOW EXIT on Remote. HIT F4 to manually add user channel VIDEO PID = 6946 AUDIO PID = 6947 (always one up from video no matter what!!) PCR PID = 6946 HIT ENTER on remote Now hit exit & save !!! NOW WATCH Cartoon Network!!! This is for bird 110* Alot more testing is under way for other channels and wondering if channel editor can be used to manually enter tp's and channel pids for each bird! Will post results at a later time for other channels __________________ testing viewsat ultra pansat 2700 n2 lifetime classic na co-olsat 5000 vs platium vs extreme cw 800 vs ul cs 6100 Sponsored Links Tired of waiting days for fixes? Click here to get 3000 channels.. NO DOWNTIME, Guaranteed! musky View Public Profile Send a private message to musky Find all posts by musky Add musky to Your Contacts #2 (permalink) Today, 03:19 AM daveo4567 ViP Member Join Date: Nov 2007 Posts: 22 Works, Thanks for sharing. daveo4567 View Public Profile Send a private message to daveo4567 Find all posts by daveo4567 Add daveo4567 to Your Contacts #3 (permalink) Today, 03:25 AM Shinano-1 ViP Member Join Date: Jul 2006 Posts: 143 It Work on xtreme -------------------------------------------------------------------------------- I tried work on xtreme just 1 channel Shinano-1 View Public Profile Send a private message to Shinano-1 Find all posts by Shinano-1 Add Shinano-1 to Your Contacts #4 (permalink) Today, 04:21 AM rockyj ViP Member Join Date: Oct 2007 Posts: 41 hello I tried it on my ultra got picture no audio is their something I can do for audio thanx rocky rockyj View Public Profile Send a private message to rockyj Find all posts by rockyj Add rockyj to Your Contacts #5 (permalink) Today, 05:37 AM wipf30 ViP Member Join Date: Apr 2008 Posts: 16 hi everyone, i tried what Musky is offering on my viewsat platium lite and it worked for me , i got 2 channels now it's better then not having any, i got channel 11399 (CTN) and ch. 09979 ( ion t.v.) good luck to everyone, wipf30 View Public Profile Send a private message to wipf30 Find all posts by wipf30 Add wipf30 to Your Contacts #6 (permalink) Today, 05:53 AM SmittyKool ViP Member Join Date: May 2009 Posts: 5 Job Well Done! SmittyKool View Public Profile Send a private message to SmittyKool Find all posts by SmittyKool Add SmittyKool to Your Contacts #7 (permalink) Today, 01:40 PM The Wufman ViP Member Join Date: Apr 2009 Location: lurking amongst the shadows Posts: 99 Try this for up to 6 channels -------------------------------------------------------------------------------- I can confirm this to be currently working for these channels on sat 110 on all my receivers: 7/03/09 These Channels Confirmed Working At Present C & P 6 channnels have become available by manually inputting PID info into your TP information menu. To do this, go to your Channel Scan Menu for DN 110. Select TP 12486, then select 'Add user channel' (F4) on some units. You must then fill in the V, A and P lines with the following information. When finished each entry..hit the OK button. For the moment it is best to keep Auto TP OFF but keep your normal EPG as you can use this as reference for programming guide for these channels. A 'User Channel List' will be created below channel 100 in your EPG. These channels will have no numbers on them....so the list below will give you their associated channels for reference. If any further channels are acquired, please advise in this thread and I will add them on...thanks. Important Announcement: These channels are all coming FTA. No bins required. This means that these channels should be available on every receiver that is getting DN 110. 177 - Cartoon Channel West V6946 A6947 P6946 181 - N (Nogin channel) V4130 A4131 P4130 217 - ION W - Alternative Time selection to ION Channnels on FTA V6434 A6435 P6434 267 - CTN (Religious Programming) V6690 A6691 P6690 867 - BDMAX - Spanish Language Channel V6178 A6179 P6178 Also one channel working for DN promo NOTE:Not all receivers work the same way as far as how to input this info manually;refer to your receiver section to find out any info for your brand/model if unsure of how to do this. |
Silver Member Username: RocasHumble, Tx Harris Post Number: 131 Registered: Aug-07 | hola a todos tengo una pregunta estube tratando bajar algunos otros pajaros y tube exito gracias a ustedes pero la pregunta es la siguiente les a pasado a ustedes que la barra de calidad en su reciever se va de 0 a 100 para ariba y para abajo? bueno ese es el problema que tengo porque ahora ni siquiera puedo agarrar los pajaros mas facil (110,119) es un vs exremme necesito ayuda por favor nota estoy usando los lnb correctos para cada pajaro ise defaul para borrar todo y aun asi nada gracias y ojala algun maestro me pueda ayudar |
Silver Member Username: OldgreenPost Number: 202 Registered: Dec-07 | Hello Underground Community: Quisiera saber si alguien que se encuentre en Canada esta captando señal de Hispansat..... Gracias de antemano Oldgreen |
Silver Member Username: DilanGUADALAJARA, JALISCO MEXICO Post Number: 128 Registered: Dec-07 | juan loeza,,te dejo esta info,,de los lnbs....200 pesos usados,,,es lo que dice,,,si quieres nuevo ve a cp electronics esta por americas y pablo neruda,,,o tres w punto cpelectronics punto com |
Silver Member Username: DilanGUADALAJARA, JALISCO MEXICO Post Number: 129 Registered: Dec-07 | Lnb amazonas de mayoreo Lnb dms internacional es el lnb mas fuerte da 10% mas de calidad que cualquier lnb y tiene 2 salidas por si quisieran agregar un 2do decodificador a su casa Uno solo $450 y mas de 10 $300 Tambien tenemos lnb lineal para amazonas o cualquier satelite Uno solo $200 y mas de 10 $100 Si compra mas de 10 lnbs les voy a pasar informacion que vale oro Un transponder para buscar amazonas que da 100% de nivel y 100% de calidad hasta con antena de 1.80 para que no les cueste nada de trabajo encontrar el satelite solo con dms internacional ademas de 7 tps para abrir todos los canales con 5 puntos mas Ademas tenemos decodificadores antenas de todos tamaños tambien vendemos moldes de channel master equipos ikas y tambien tenemos una maravilla de antena para mazonas que da de nivel 70% en el transponder mas fuerte y 65% en el tp mas debil esta muy fuerte queda 40 puntos arriba antes de cuadricular el canal, suporta lluvias, la antena es original y mide 2.40 mts vale $5000 ademas de que abre cualquier satelite fta (free to air) que se le ponga enfrente le saca el mayor nivel posible y se le puede agregar un 2do brazo para ver un satelite libre que tiene el canal de telemundo para ver futbol Precio: 100 pesos Nombre: Hashfta Ubicacion: Guadalajara, Jalisco Celular: 3314194653 |
Silver Member Username: Sergio_verdugoHermosillo, Sonora Mexico Post Number: 929 Registered: Nov-07 | JAVI BUENA APORTACION |
Gold Member Username: Javy_gzaPERROS BRAVOS , NUEVO LEON Post Number: 2189 Registered: Oct-06 | SALUDOS A LA RAZA OK SERGIO VERDUGO . SALUDOS |
Bronze Member Username: Portero_bcPost Number: 12 Registered: Aug-08 | Dilan muy completa tu inf. gracias y tomare encuenta toda esta, disculpa mi pregunta: tu te dedicas profesionalmente a esto de fta o simplemente lo ejerces de joby? gracias. |
Silver Member Username: DilanGUADALAJARA, JALISCO MEXICO Post Number: 130 Registered: Dec-07 | juan loeza,,,yo no me dedico,,a eso es puro pasatiempo,,la circustancias del terreno donde vivo,,no me dejan agarrar la señal de la tv abierta,,estoy muy abajo,,ni con 15 mts de altura agarro la señal libre...pero es bonito este joby |
Silver Member Username: Pacha19Post Number: 251 Registered: Nov-07 | Saludos a todo el foro =) |
Silver Member Username: OldgreenPost Number: 203 Registered: Dec-07 | Para Juan gonzalez Una vez tuve ese problema..... Tuve que cambiar un condensador dañado en la placa electronica del receiver. Puede ser o no lo que te genera el problema. Apaga y desconecta todo.... Abre la caja y revisa si alguno de los condensadores se encuentra quemado o se ve un poco "inflado"...... si es asi, debes cambiarlo. Esto ocurre porque el medio ambiente donde se encuentra el receiver es muy seco. Normalmente ocurre en invierno por la calefaccion. Suerte Oldgreen |
Silver Member Username: ElparranderoLos angeles, Ca Los angeles Post Number: 286 Registered: Dec-07 | hola saludos ,a todos ,,alguien save cuantos canales se ven en ,, nfusion solaris,,,por ke no tengo idea por el momento,,,de antemano gracias |
Bronze Member Username: FletesMontreal, Quebec Canada Post Number: 28 Registered: Aug-08 | Hola A todos! como estan? alguin me podria informar sobre el satelite satcom c4 quisiera saber si hay canales en espanol y si lo puedo captar en canada. gracias de antemano por cualquier information util que me puedan proveer. Gracias! |
Silver Member Username: OldgreenPost Number: 204 Registered: Dec-07 | Jesus: Puedes encontrar toda la informacion en: http://www.lyngsat(punto)com/ reemplaza punto por . Oldgreen |
Silver Member Username: Viejo_pedroPost Number: 208 Registered: Nov-07 | buenas a todos del forun, esto es un mensaje para los amigos que les gustaria ver tv en internet canales ecuatoriano colombiano cubanos y argentinos, no hay que registrarse es gratris hay como 12 canales de deportes peliculas y noticias en www.elastillero.com hasta que venga la luz |
Silver Member Username: Viejo_pedroPost Number: 209 Registered: Nov-07 | disculpa son 21 y hay un canal brasilero y 4 emisora de radio |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1205 Registered: Oct-07 | solo uno: Son 48 canales en DN. Esta es la lista que puso hace dias el buen Fred Olavarria: 106 TVLND 108 LIFE 109 LMN 120 HIST 121 HISTI 122 SCIFI 125- PIRATE TV 127 OXYGN 128 we 129 BRAVO 130AMC 131 IFC 132 TMC 136 FX 168 SPIKE 169 NOG/N 170 NICK 171 NICKW 172 DISE 173 DISW 174 TDIS 175 BOOM 213 NASA 216 C&T 240 INFO 262 ANGEL 280 FREE 298 FREE 300 Hbo-E 301 Hbo-2e 302 Hbost 303 Hbo-w 304 Hbo2w 305 Hbofm 307 Hbocy 309 Hbolt 329 TMC-W 330 TMCXW 341 ENCRW 342 EWSTN 343 EACTN 344 EMYST 345 EDRAM 346 ELOVE 347 EWAM 350 STARZ 351 STRZW 353 SCINE 354 STZC 355 SBLCK 356 SK&FM Y si apuntas al Nimiq 1, vas a tener muchisimos mas canales. Saludos |
Gold Member Username: Javy_gzaPERROS BRAVOS , NUEVO LEON Post Number: 2190 Registered: Oct-06 | WENO RAZA AHORA VOI X EL HISPASAT 1 C , D NOMAS Q ME DIGAN CUAL TP TIENE MAS SEYAL PA LA RAZA DE MTY O DE DDE SEA . SALUDOS NOTA LO Q PASA Q TENGO UN ARBOLOTE ENFRENTE DE MI CASA A VER SI NO ME ESTORBA. SALUDOS |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1206 Registered: Oct-07 | Aqui pueden encontrar el listado completo de los canales de DN y BEV que se estan viendo actualmente con Nfusion Solaris para arriba. Lista actualizada al dia de hoy. [link removed] Saludos. |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1207 Registered: Oct-07 | Javy Gza: El Tp con mas fuerza para el Hispasat es el 12052. Saludos y suerte. |
Gold Member Username: Javy_gzaPERROS BRAVOS , NUEVO LEON Post Number: 2191 Registered: Oct-06 | OK JUAN CARLOS TOMO NOTA Y ME AVENTURO A BAJARLO SALUDOS Y GRACIAS . |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1208 Registered: Oct-07 | Un verdadero placer poder ayudar a los demas compañeros del mismo pasatiempo. Saludos. |
Silver Member Username: OldgreenPost Number: 205 Registered: Dec-07 | Hello Underground Community: Para los interesados en Hispasat y Amazonas pueden encontrar algo de informacion en: Saludos Oldgreen |
Silver Member Username: BorinickPost Number: 520 Registered: Mar-07 | tengo una pregunta mi queridos de este foro feliz dia de independencia a todos es que canales se ven en las amazonas ? |
Bronze Member Username: Negro2tityPost Number: 57 Registered: Apr-06 | Emilio, confirmo que trabaja tu aportacion en el VS Platinium...si tienes mas, con todo te agradeceria compatriota... Roger out, desde winnipeg |
Gold Member Username: Canada_havanaCanada Post Number: 2033 Registered: Sep-07 | BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,,,, |
Bronze Member Username: Negro2tityPost Number: 58 Registered: Apr-06 | Emilio trabajara los mismos settingdel VS para el Pansat 27k00? los voy a probar hay te aviso.. |
Gold Member Username: Canada_havanaCanada Post Number: 2034 Registered: Sep-07 | MANNY,,, ESTOS SON LOS RECIVER QUE SE TESTEARON,,,,,, ALGUNOS CAMBIAN LOS SETTING , PERO ES LO MISMO.....testing viewsat ultra pansat 2700 n2 lifetime classic na co-olsat 5000 vs platium vs extreme cw 800 vs ul cs 6100 |
Bronze Member Username: Negro2tityPost Number: 60 Registered: Apr-06 | Emilio, garcias pero cuando trato de agregar otro canal, solo cae encima del anterior, es decir no puedo agregar mas que uno, me puedes dar el manner way como lo puedo h@cer...gracias.... Winnipeg out |
Silver Member Username: Viejo_pedroPost Number: 210 Registered: Nov-07 | buenos dias a hesa jente linda del forun . disculpe que puse mal la direccion de los canales en internet tv, en especial para los ecuatorianos por que hay como 8 canales del ecuador. http;//www.elastillero.tv |
Bronze Member Username: JoseluisMeXiCaLi Post Number: 59 Registered: Oct-06 | buen dia estimados foristas quisiera saber que equipo IKS funciona mejor con internet telnor, o mas bien dicho modem/router 2WIRE que es el que proporciona telnor con el servicio inalambrico este tiene 4 puertos ethernet como algunos de ustedes saben. ya he hecho algo de lectura sobre los equipos en si, estoy un poco inclinado hacia kbox o quizas CNX nano con dongle pero quiero saber que tal funcionan con este modem/ router 2WIRE. les agradezco sus opiniones , su experiencia. |
Bronze Member Username: EspartanoPost Number: 73 Registered: Jan-08 | buenos dias a todos, tenfo un Fortec (Flu) convertido a PUFF, despues de todos estos cambios ya no tengo senal, puedo seguir utilizandolo? que debo de h@cer para ver canales? tengo una antena Pish Pro con un LNB. espero sus comentarios. saludos a todos. |
Bronze Member Username: JoseluisMeXiCaLi Post Number: 60 Registered: Oct-06 | parece que conaxsat nano esta apenas haciendo pruebas, creo que le falta un poco, sin embargo tiene muchos canales. kbox parece que tiene mucha estabilidad. si alguien de mexico los ha probado a ver si puede compartir su experiencia |
Bronze Member Username: JoseluisMeXiCaLi Post Number: 61 Registered: Oct-06 | joshua los flu soportan hasta hoy solo n2 por lo pronto no hay fixx para n3 tu flu no podra abrir nada ahora. solo hay que esperar o buscar un sistema iks |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1209 Registered: Oct-07 | Joshua: Como dice José Luis, no hay nada en DN ni BEV para tu caja, pero por qué no pruebas como FTA? Te lo recomiendo mucho, ya que hay muchos canales libres, solamente es cosa de buscarle. No nos quedemos con la idea de que si no hay ND o BEV no hay nada que ver. SEAMOS CREATIVOS POR FAVOR. Saludos |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1210 Registered: Oct-07 | Fred: Tendras un numero telefonico donde te pueda contactar? Necesito que me ayudes con un problema que tengo sobre la Solaris. Saludos |
Bronze Member Username: Nikk_mtyPost Number: 100 Registered: Jul-08 | Como lo posteo Emilio mas arriba, hay alrededor de 5 a 7 canales que no estan codificados y que se pueden ver en cualquier receiver... Pueden usar el Channel master para crear una lista de canales en el sat 110 o Echo 8.1, manualmente agregan un TP con frec 12486, polaridad vertical, 20.000 Msps, luego agregan uno por uno manualmente los canales: 177 - Cartoon Channel West V6946 A6947 P6946 181 - N (Nogin channel) V4130 A4131 P4130 217 - ION W - Alternative Time selection to ION Channnels on FTA V6434 A6435 P6434 267 - CTN (Religious Programming) V6690 A6691 P6690 867 - BDMAX - Spanish Language Channel V6178 A6179 P6178 Luego esa lista se la bajan a su receiver |
Bronze Member Username: EspartanoPost Number: 74 Registered: Jan-08 | y que tengo que h@cer para ver FTA? esta antena y equipo me sirven? tengo que cambiar la orientacion de la antena? bajar algun bin especial? en que me puedo apoyar disculpen mi ignorancia saludos a todos |
Silver Member Username: Tetuscosmicus, Post Number: 513 Registered: Apr-08 | Espartano... Lo unico que tienes que aser es ir donde esta tu antena y mover....para esto tienes que estar informado de que sat, vas a vajar..o como dices la orientacion del sat. bin en especial no hay... talves as leido arriva que bins no hay ...solo para siertas cajas....yo te recomendaria que leas mas arriba para informarte mas. haaaaaaaaaaa..te recomiendo las yaves necesarias para tus tornillos de la antena...importante heeeeeeeeeeeee... Saludos mi amigaso y mucha suerte con los Sat,, |
Silver Member Username: Tetuscosmicus, Post Number: 514 Registered: Apr-08 | Y ablando de amigasos.. Saludos Maestro..que Dios lo cuide en union de su familia... y gracias por la lista............... |
Silver Member Username: LesiPost Number: 114 Registered: Aug-07 | buenas tardes y saludos a todos los del foro feliz dia de la independencia a todos |
Silver Member Username: Mcd500Post Number: 141 Registered: Mar-08 | senores maestros me pueden ayudar como agarar la senal las amasonas en los angeles en cw650 clasic acaba de salir un bin 179 para las amasonas oalguen espligue para gue es ese bin grasias |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1211 Registered: Oct-07 | mario h: Ese bin es efectivamente para el Amazonas, pero la verdad dudo que puedas captar ese satélite desde tu ubicacion, ya que esta mucho mas hacia el sur su huella. A menos que tengas una antena de entre 2.4 y 3 metros. Saludos |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1212 Registered: Oct-07 | Joshua: Para poder captar señales FTA, vas a necesitar un lnb lineal o universal, y revisar primeramente la pagina de lyngsat, para que cheques los canales y las huellas de los satélites. Saludos |
Silver Member Username: LilfredMEXICO, D.F. MEXICO Post Number: 276 Registered: Oct-07 | juan carlos 56575641 |
Silver Member Username: OldgreenPost Number: 206 Registered: Dec-07 | Hello Underground Community: Aqui esta la huella del Amazonas en América del Norte |
Silver Member Username: OldgreenPost Number: 207 Registered: Dec-07 | La huella muestra que es mas fuerte la señal en California que en México...... Asi es que adelante Mario H. Busca la antena y el LNB adecuados y agarra ese pajaro. Oldgreen |
Silver Member Username: OldgreenPost Number: 208 Registered: Dec-07 | La misma huella dada por Lyngsat: |
Silver Member Username: OldgreenPost Number: 209 Registered: Dec-07 | Tamaño de antenas para Amazonas en América del Norte, segun Lynsat: dBW------- Diametro (cm) 48 ------- 60-75 47 ------- 65-85 46 ------- 75-95 45 ------- 85-105 44 ------- 95-120 43 ------- 105-135 42 ------- 120-150 41 ------- 135-170 40 ------- 150-190 |
Bronze Member Username: EspartanoPost Number: 75 Registered: Jan-08 | ok, desenme suerte con la pesca de los sats, ahi les comento como me fue. muy agradecido con sus comentarios. abur! |
Silver Member Username: JuanchgPost Number: 212 Registered: Jul-06 | estoy por comprar un nfusion, y quisiera saber cual es el mejor de los diferentes tipos que hay en el mercado. Saludos cordiales, |
Silver Member Username: OldgreenPost Number: 210 Registered: Dec-07 | Hola a todos nuevamente: Debo realizar algunas aclaraciones al respecto del Satélite Amazonas 61 grados. Aunque existe una huella bastante potente en América del Norte, este servicio no emite por ahora ninguna señal de television. Para lograr captar alguna señal de television del Amazonas 61 en Norteamérica se requiere una antena entre 2.5 y 3 metros de diametro. Puesto que las señales de TV emitidas actualmente estan enfocadas hacia América del Sur. Trascribo algo encontrado en otro foro: "Note: Use the "America" map, NOT the "North America" map. The North America map is meant for future service in the Ku Band. The "telefonica" signal is KU band but meant for Brazil and South America. You can see in the map that it gets ridiculously weak north of there. People in the Caribbean with 10 ft+ dishes manage to get it. The "Beam" column in the frequency chart at Lyngsat tells you which beam (and thus which map) carries what channels, you'll see there's no current North America beam in the Ku band." Por tanto es bastante complicado lograr algo de señal de este pajaro en América del Norte. |
Silver Member Username: Mcd500Post Number: 142 Registered: Mar-08 | olgreen senal encontrada pero no abre ningun canal estoy usando pajaro 3metros biejo gue se usaba antes espero lograr mi objetibo grasias a todos los maestros |
Silver Member Username: OldgreenPost Number: 211 Registered: Dec-07 | Hola a todos nuevamente: Debo realizar algunas aclaraciones al respecto del Satélite Amazonas 61 grados. Aunque existe una huella bastante potente en América del Norte, este servicio no emite por ahora ninguna señal de television. Para lograr captar alguna señal de television del Amazonas 61 en Norteamérica se requiere una antena entre 2.5 y 3 metros de diametro. Puesto que las señales de TV emitidas actualmente estan enfocadas hacia América del Sur. Trascribo algo encontrado en otro foro: "Note: Use the "America" map, NOT the "North America" map. The North America map is meant for future service in the Ku Band. The "telefonica" signal is KU band but meant for Brazil and South America. You can see in the map that it gets ridiculously weak north of there. People in the Caribbean with 10 ft+ dishes manage to get it. The "Beam" column in the frequency chart at Lyngsat tells you which beam (and thus which map) carries what channels, you'll see there's no current North America beam in the Ku band." Por tanto es bastante complicado lograr algo de señal de este pajaro en América del Norte. |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1213 Registered: Oct-07 | Oldgreen: Precisamente a eso me referia. La huella que pusiste es para América del Norte, si, pero para banda C, no para Ku. Y sip, también, Telefonica transmite con dos huellas, una para Brasil (que no llega ni siquiera a Guatemala) y otra para América del Sur (que es la que se promueve en el foro). Cuidado con confundir a los demas. Ah, y no me lo tomes a mal, no es para molestarte. Saludos |
Gold Member Username: JuancholagartoMexico City, D.F. Mexico Post Number: 1214 Registered: Oct-07 | Para el Amazonas: En el D.F. se puede bajar con un plato a partir de 1.2 metros, con solamente el 35 a 38 % de canales. Todos los transponders a partir de un plato de 1.8 metros. Solamente deben tener cuidado con el skew del lnb (IMPORTANTISIMO). Mi problema con mi antena de 2 metros es que los soportes no son originales, por lo que lo mas seguro es que estén de mal tamaño. Mañana voy a conseguir unos clonados de los originales y haré pruebas nuevamente, para poder reportar resultados. Saludos |
Bronze Member Username: HuizarjchrTijuana , Baja califor... Mexico Post Number: 12 Registered: Feb-07 | hola se dice que el viusat se ven 6 o 7 canales y tambien en 650 pansat que estan libres acabo de verlo en otro foro sera cierto llagando a la casa checo en mi c.v 800 sino en clon de panson |
Gold Member Username: Canada_havanaCanada Post Number: 2035 Registered: Sep-07 | BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,, |
Gold Member Username: Canada_havanaCanada Post Number: 2036 Registered: Sep-07 | MANNY,,,AQUI TE VA,,,,,,,DESPUES DE AGREGAR UN CANAL APRIETA EL ,,, OK ,,, Y DRSPUES EL ,,, F4 ,,,,, Y ASI ASTA QUE TERMINE....BENDICIONES. |
Bronze Member Username: Ritchie_betanzosMontreal, Quebec Canada Post Number: 62 Registered: Sep-06 | hola alguien sabes si hay noticias sobre nuevos bins para sonicview 4000 para poder abrir los canales en nagra 3? alguien tiene alguna informacion? |
New member Username: MdcmdiezMiami, Fl Dade Post Number: 9 Registered: May-06 | Saludos companeros. Por favor alguien me puede decir sin aun nada de nada...tengo mi pansat convertida a puff lezma...Ya existe algo?, que tanto hay que esperar? no veo television desde hace semanas. Por favor me podrian actualizar??? |
Gold Member Username: Canada_havanaCanada Post Number: 2037 Registered: Sep-07 | asta el momento no hay nada tendremo que seguir esperando..........saludos jose ricardo,,,, BENDICIONES. |
Gold Member Username: Canada_havanaCanada Post Number: 2038 Registered: Sep-07 | CARLOS M,,,, solamente asta el miomento ahy esta occion,,,,,,con 5 canales free. #1 (permalink) 3rd July 2009, 02:13 AM musky ViP Member Join Date: Aug 2007 Posts: 1,274 Confirmed 177 CN working..chirp method VS ULTRA -------------------------------------------------------------------------------- Confirmed 177 CN working..chirp method VS ULTRA confirmed by me. Confirmed 177 CN working..chirp method VS ULTRA VS ULTRA Delete all channels by going to: Menu and selecting: Edit channels: Right arrow to select delete: and hit f3 to delete all channels. exit and save Now goto Channel Scan Satellite ( Pick ********110*) Network Search (OFF) Scroll down to edit transponders Hit F3 button on remote & DELETE ALL TRANSPONDERS After deleting hit F1 on remote to add user transponder. Freq = 12486,S/R = 20000,Pol = V,FEC = 5/6,TV & Radio will be zero because I'ts not saved yet. NOW EXIT on Remote. HIT F4 to manually add user channel VIDEO PID = 6946 AUDIO PID = 6947 (always one up from video no matter what!!) PCR PID = 6946 HIT ENTER on remote Now hit exit & save !!! NOW WATCH Cartoon Network!!! This is for bird 110* Alot more testing is under way for other channels and wondering if channel editor can be used to manually enter tp's and channel pids for each bird! Will post results at a later time for other channels |
Gold Member Username: ViancheMontreal, Quebec Canada Post Number: 1047 Registered: Sep-06 | buenos dias una pregunta todo eso que dice de buscar el tp y poder ver cartoon sirve para la caja pansat convertida lzma puff puedo hac er eso en mi caja? |
Gold Member Username: Canada_havanaCanada Post Number: 2039 Registered: Sep-07 | CARLOS M,,, SON PARA ESTOS RECIVER QUE SE TESTEARON,,,,,viewsat ultra pansat 2700 n2 lifetime classic na co-olsat 5000 vs platium vs extreme cw 800 vs ul cs 6100 |
Silver Member Username: JuanchoCANADA Xx Post Number: 747 Registered: Jun-08 | vivian diaz, puedes ver cartoon network en esa caja, se hace asi Menu--->Installation--->Advance scan--->Choose Exho 8.1/KU en los satellites 110w sat En Down frequency, entra 12486 o busca este TP' con el remote Symbol Rate y Polarity, leave como esta (20.000 Msps y Vertical) ejemplo Video PID, entra 6946 Audio PID, entra 6947 PCR PID, entra 6946 #151 - V6690 A6691 P6690 #177 - V6946 A6947 P6946 cartoon n #181 - V4130 A4131 P4130 #233 - V4146 A4147 P4146 #267 - V6690 A6691 P6690 en los pansats cada canal que actives, tienes que ir a canal edite y renombrarlo o de otro modo te cambiara de un canal al otro y no pasara de un solo canal, |
Silver Member Username: RocasHumble, Tx Harris Post Number: 132 Registered: Aug-07 | hola a toda la raza perdonen lo ignorante una pregunta ,esto de los canales (escondidos) que cambiando el video etc.y se logran ver podria ser que de alguna manera se pueden ver otros sin tener estas cajas sin n3? otra pregunta para bajar el hispasat ya tengo el plato necesario el lnb tambien ya se que esta a 30:w lo unico que necesito es saber de alguien que ya lo tiene funcionando es si tengo que mover el skew y para donde tomando en referencia a el reloj muchas gracias de antemano. |
Silver Member Username: PasisLeon, Guanajuato Mexico Post Number: 899 Registered: Jul-06 | buenas tardes a toda la banda aqui regreso con mas ignorancia cada vez,y con mas verguenza por tantas mentiras de este partido en el poder y sus maranadas, ademas del miedo q les esta metiendo a la poblacion para q ellos sean los salvadores de la nacion, jajajajajajaja en fin, pasemos a lo nuestro nikk oye necesito volver a un convertido lzma a puff y es q quiero usarlo para bajar el amazonas, si m puedes orientar te lo agradeceria y si tienes el fix para bajar el amazonas pues mejor, o si alguno sabe como ha cer lo q necesito les agradeceria su amable colaboracion, es q ya estoy bien aburrido con el megacable, q aun q el sistema m da el internet gratis pues esta muy aburrida su programacion, bueno de ante mano muchas gracias al q conteste y aribaaaaaaaaa la razaaaaaaaaaa |
Silver Member Username: KoritaFRANCIA, CA Post Number: 198 Registered: Feb-08 | SALUDOS A TODO EL FORO EN GENERAL AL GUIEN MEPODIA CONFIRMAR SILAS NFUSION ESTAN TRABAJANDO SELOS AGRADECERIA MUCHO |
Silver Member Username: JggHouston, Tx Usa Post Number: 106 Registered: Nov-06 | PIMP....... si estan trabajando las nfusion. cuando menos la solaris, con los pocos canales que se ven. pero estan trabajando. |
Silver Member Username: Mcd500Post Number: 143 Registered: Mar-08 | senores maesros me podia cofirmar si esta trabajando sonic view elite grasias |
Silver Member Username: KoritaFRANCIA, CA Post Number: 199 Registered: Feb-08 | jgg..... GRACIAS YA LA PUSE A FUNCIONAR |
Silver Member Username: RescateVENEZUELA, M... Post Number: 369 Registered: Nov-07 | Por ahora solo funciona IKS, todas las demas cajitas, vendanlas o utilicenlas en FTA por el momento, comprense una con IKS (necesita coneccion internet cuando estan viendo tv) Todas las que estan trabajando con IKS son estas: nfusion - menos la NOVA sonicview kbox ilink conaxat Yo espero recibir mi kbox el lunes proximo o el martes. Escogi este porque tiene muchos canales latinos y ademas por el buen servicio a los clientes. Saludos |
Silver Member Username: Tetuscosmicus, Post Number: 515 Registered: Apr-08 | Saludos mi moi...gusto de leerte cuidate....y cuidado con las cahuamas jejejeje....mass si es en el techo... cuidate...... |
Silver Member Username: RocasHumble, Tx Harris Post Number: 133 Registered: Aug-07 | hola a todos tengo una molestia para cualquier viewsat owner necesito saber el code para una television hitachi ya que yo perdi mi manual del viewsat gracias. |
Bronze Member Username: Guillo54Montreal , P,Q. Post Number: 50 Registered: May-06 | emilio que bin le pongo a una life time ultra, gracias |
Silver Member Username: JggHouston, Tx Usa Post Number: 107 Registered: Nov-06 | Juan Gonzales...... 005. 006. 007. 016. 018. 067. 068. 069. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 119. 123. 124. 143. 151. 161. 171. 179. esas son para hitachi espero te sirvan, saludos...... |
Silver Member Username: RocasHumble, Tx Harris Post Number: 134 Registered: Aug-07 | jgg muchas gracias ya funciono eres de houston? |
Bronze Member Username: LeonazulkremaCHICAGO, IL USA Post Number: 17 Registered: Aug-05 | ando un poquito fuera de onda por que andube de vacaciones. alguien me podria decir si la pansat 3500 esta trabajando o simplemente no esta trabajando ninguna? estube en mexico por 3 meses y no la he podido arreglar por favor alguien que me pueda orientar. se los agradesco. muchas gracias. |
Silver Member Username: Rober2154Miami, Fl Usa Post Number: 579 Registered: Jun-06 | Alguien ha testeado las Kbox, aqui en Miami se estan vendiendo, dicen que abrio los latinos y los 300 y PPV.... |
Gold Member Username: Canada_havanaCanada Post Number: 2040 Registered: Sep-07 | BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,,,,,, |
Silver Member Username: DilanGUADALAJARA, JALISCO MEXICO Post Number: 131 Registered: Dec-07 | saludos a todos los de este foro,,, reportando,,, desde guadalajara,,decirles que ayer caze este pajaro hispansat 30 w con 49 canales la mayoria latinos y 5 arabes solo tarde en bajarlo una hora aprox..gracias a la alarma sonora con la que cuenta el pansat 2700a muy buena herramienta,,,y una brujula,,saludos antena sky y lnb lineal chaparral,,en gdl el lnb no ocupa screw... |
Silver Member Username: Delgado258376Monterrey Post Number: 318 Registered: Aug-06 | Quien en Monterrey ya pesco el Amazonas, de favor para que me den algAºn tip. |
Silver Member Username: VikosolisMonclovaMexico Post Number: 298 Registered: Nov-06 | buenas tardes! si no sera mucha molestia, kiero bajar el hispasat con mi pansat convertido 2700, pero ke bin necesito y con que tipo de lnb lo puedo captar? de antemano agradezco, saludos |
Silver Member Username: NeoxTijuana, Baja California Mexico Post Number: 403 Registered: Aug-06 | Antes que nada Buenos dias a todos los F.T.A-migos del foro por el bin comun. DILAN DELGADO Una pregunta el LNB que usaste para para el Hispa es el mismo del SKY y en que tipo de lnb configuraste el P2700 universal 1 o 2 o como standar. De ante mano grasias |
Silver Member Username: DilanGUADALAJARA, JALISCO MEXICO Post Number: 132 Registered: Dec-07 | VIKTOR SOLIS NO NESECITAS NINGUN BIN,,YA QUE LA MAYORIA DE LOS CANALES ESTAN LIBRES,, EL LNB ES LINEAL STANDAR,,Y CON TU PANSAT SI LO BAJAS SALUDOS |
Silver Member Username: DilanGUADALAJARA, JALISCO MEXICO Post Number: 133 Registered: Dec-07 | NEO X SI... EFECTIVAMENTE ES EL MISMO DE SKY, STANDAR... AQUI EN GDL ME DIO HASTA 84% DE CALIDAD SALUDOS |
Bronze Member Username: AlejandramxPost Number: 87 Registered: Mar-08 | Tengo un pansat3500 con una antena dish500 doble lnb , me gustaria saber que satelites podria orientar ? |
Bronze Member Username: Jorge125Mexico, Tonala Jalisco Post Number: 32 Registered: Sep-08 | Saludos al foro alguien sabe si esta funcionando el pansat 2700 para agarrrar amazonas y si no que codificador me recomendarian, y como utilizan la alarma del pansat 2700 para localizar satelites ya que pues soy novato en esto de tratar de localizar satelites y cualquier ayuda me seria muy util se los agradeceria mucho Saludos |
Silver Member Username: RescateVENEZUELA, M... Post Number: 370 Registered: Nov-07 | Ya me llego el kbox, como prometido por Transat Electronics, lunes 6 de julio, me llego a las 3:30, me preparo para instalarlo. Continuare informando del resultado del "testing" Nadie quiere comprar mi nfusion nova??? Cuanto dan... jejeje Ni los que dicen que tienen fe en nfusion lo quieren comprar Saludos |
Silver Member Username: ElmoxpOttawa, Ontario Canada Post Number: 300 Registered: Jun-06 | Que bien muchacho, ahora para los que tienen el Kbox, salen todos los canales Latinos? y bev? si se puede poner la lista de los canales seria fabuloso, estoy pensando en hacerme de uno, ahora se puede usar como FTA tambien? tiene Sonido Optical para esos canales que no se pueden escuchar? Gracias |
Silver Member Username: VikosolisMonclovaMexico Post Number: 299 Registered: Nov-06 | muchas gracias dilan con ke TP lo puedo encontrar y cual es su ubicacion (del hispasat)??? tengo 2 antenas con las ke captaba los 110 y 119 los LNB kreo ke son de dish americano me sirven esos? |
Silver Member Username: Sergio_verdugoHermosillo, Sonora Mexico Post Number: 930 Registered: Nov-07 | ESTOY FRITO NI COMPIU NI TV |
Silver Member Username: RescateVENEZUELA, M... Post Number: 371 Registered: Nov-07 | Ŀa caja es similar a la nfusion las mismas conexiones exepto el puerto ethernet que no tiene, ya que se comunica con el khub. Ademas tiene la entrada USB. Ok ya esta instalada, facil de instalar solo cargar tres bines lo cual se hace con la USB que viene incluida, hay un poco de friseo que dura entre 1/2 segundo y 10 segundos pero es muchiiiisimo mejor que nada.! Creo que para los que vivieron la transision de n1 a n2 que dicen que duro tres meses en negro y ahora que por lo menos dicen que kbox saco canales a las 3 horas, ha habido un gran avance. Por ahora nfusion nova se queda en su caja, y la pansat solo con cartoon networks. Saludos |
Silver Member Username: RocasHumble, Tx Harris Post Number: 136 Registered: Aug-07 | raza como dijo (kiko) me doy ya probe con pansat,viewsat y nada no agarro calidad para encontrar HISPASAT cualquiera que ya tubo exito podria ser tan amable y poner una grafica de como estan todos los settings please , please no les cuesta nada no sean malos de antemano gracias. |
Bronze Member Username: ColarilloXxxxxxxxxxxxxxxxxx, Xxxxxxxxxxxx... Xxxxxxxxxxxx... Post Number: 93 Registered: Nov-07 | senores a quien pueda alludarme nesecito agarrar univision solo quuisiera me dijeran a que pajarraco debo de apuntar,que tamano de plato y que lnb yo nesecito por aca ando ahora en el are de CA USA DE ANTEMANO SE LOS AGRADESCO .........................GRACIAS.......................... |
Gold Member Username: Canada_havanaCanada Post Number: 2041 Registered: Sep-07 | BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,,,,,, |
Gold Member Username: ViancheMontreal, Quebec Canada Post Number: 1048 Registered: Sep-06 | buenos dias a todos hola juan muchas gracias por tu respuesta pero tengo un problema mas cuando entro a tratar de canbiar el video pid y el audio y el pcr, al lado de cada uno de ellos dice auto y no puedo cambiarlos el control remoto no hac e nada cuando llego a ese punto sera que hay otra manera para que yo pueda agarrar eso canales ya hice todo lo demas ya tengo el tp 12486 pero no puedo continuar cfon la otra parte, hay algo que pueda yo ha cer, perodona que me demoro en contestar no siempre tengo tiempo pero igual muchisimas gracias |
Gold Member Username: Canada_havanaCanada Post Number: 2042 Registered: Sep-07 | vivian... que reciver tiene, porque yo tengo un viewsat extren,,,, y no me salen los canale,,, tambien lo ice en un co-olsat 5000,,,kl y me pasa lo mismo no me salen los canales. |
Gold Member Username: ViancheMontreal, Quebec Canada Post Number: 1049 Registered: Sep-06 | okey ya logre cambiar eso del video el pcr y todos eso meti esos numeros pero no pasa nada sola scan 0chy-a que no se k es es pro no me sale mas dime porfa que hago |
