Bronze Member Username: Simple_smithLapeer, Michigan United States Post Number: 37 Registered: Dec-08 | Any one see any flaws in my design? Sorry if its hard to see. I don't have anything on my computer to do this stuff with so i had to go old school and use the drafting table. And if you can't see its 4.775 cu.ft. @ 32 Hz for an Fi BL15 |
Silver Member Username: Woofers4lifeLexington, Tennessee Post Number: 124 Registered: Mar-09 | looks pretty solid bro. You gonna take pics as you build it? |
Bronze Member Username: Simple_smithLapeer, Michigan United States Post Number: 38 Registered: Dec-08 | Yeah for sure this time. The last build i was going take pictures, but i got in a rush and forgot to |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 3555 Registered: May-07 | what is ther port area? |
Gold Member Username: Snowball123West Allis, WI Post Number: 2925 Registered: Oct-07 | I don't think there is a need for a triple baffle up front for a single BL. You can probably just get away with double up front and bracing. Design looks solid though. |
Bronze Member Username: Simple_smithLapeer, Michigan United States Post Number: 39 Registered: Dec-08 | I don't know the port area... The port opening is 14.125" x 5" with a total length of 29.5" This is what i used to figure it out: http://www.mobileinformationlabs.com/HowTo-1Woofer-Box-CAL%20Port%20lenth%201.ht m |
Bronze Member Username: Simple_smithLapeer, Michigan United States Post Number: 40 Registered: Dec-08 | Snow, the front baffel is more for looks than strength. In the end, i hope to have this box look like a hybrid of two of PWK's boxes http://www.pwkdesigns.com/blog/index.php?entry=entry090301-100000 http://www.pwkdesigns.com/blog/index.php?entry=entry081201-100000 (hopefully) |
Bronze Member Username: Simple_smithLapeer, Michigan United States Post Number: 41 Registered: Dec-08 | I hate it when people bump their posts so this is kinda hipocritical, but i really wanted to start working on this box this weekend so... bump |
