CNX_Nano-II
Username: Oleg1474
Florida Usa
Post Number: 1297
Name : CNX-Nano-II- NPN-1.05 Beta 07-02-09
Description :
Beta file for nano II(NEW BOX)
here is the instructions and the first beta release for the Nano II
Instructions
1. Upgrade the nano2 with NPB NPN_1.05.NPN file.
2. After the upgrade goto Menu -> Accessory ->RS-232 Mode and select Type to Normal.
3. Connect the ethernet adapter to RS-232 Port.
4. Connect the Lan line to the ethernet adapter.
5. Go to Menu Installations -> Network ->set Networking Setting to Auto.
6. It should automaticly bring up your IP information then press apply.
7. When it has been set up correctly go to Bev/Dish N3 Channel and the dongle will try to connect to the server. Press OK
A. Dish and Bev should be working for now. More channels to come as we work on it.
B. If no screen shows up it mean there is a problem on the server or on the software.
Should have all channels except locals, only have adults channels 495 and 496 at this time, have all 400's sports channels, and also have all 800's latino and hope to be adding indian channels and chinese next week. No PPV on dish, No adults or PPV on bev
VOD channels are added 5816-5825.
This file is a Beta release so there can be freezing issues.Thanks Oleg Ph.D
Username: Oleg1474
Florida Usa
Post Number: 1303
We have received word from 3 Reliable sources close to www.fta-spot.com
Apparently CNX has a full working stand alone bin and will be releasing shortly. They will be releasing it soon. They are now working on securing the bin to prevent reverse engineering from the other FTA manufactures. Why would they do this? Obviously to create a monopoloy in the FTA market. Other sources are saying a reverse engineering of their code will take anywhere from 2 to 4 weeks depending on the level of security. So we shall see a stand alone fix for CNX very shortly, and the rest of the receivers with a little delay.
REMEMBER YOU HEARD IT HEAR FIRST @ www.fta-spot.com Thanks Oleg Ph.D
Username: Riconissan
Post Number: 1676
Thanks to Oleg Ph.D
Username: Oleg1474
Florida Usa
Post Number: 1304
Rico !! Captiveworks 800 v232 Telefonica
Captiveworks 700 v232 Telefonica
Viewsat 9000 HD 090706H Telefonica both gui
Viewsat max 090706HM Telefonica
Viewsat pro 090706A Telefonica
Viewsat ultra lite 090706UL Telefonica
Viewsat ultra 090706U. Telefonica
Thanks Oleg Ph.D
Username: Nydas
Post Number: 15541
Oleg Ph.D + Ph.D:
Keep it up and we will give you a third Ph.D.
Username: Saqeeb9000
Post Number: 5796
ok i got one more confirmation that nano 2 is working on all video on demand channels ..
competition is very good in iks...
