Trouble with 91 nimiq channel scanning help?
Username: Mikeymikey
hi, i found the 91w nimiq1 ku signal just fine, but when i scan, there are no channels being found at all. i have a nfusion phoenix with an 18" dish and ku-band lnbf LO:11.25GHZ. can anybody help me solve this problem? thanks
Username: Plymouth
Post Number: 10053
Mikey
Try this setting
LNB Type: Standard
LO Freq: 11250
Diseq: choose the good port
Lock Tp: 12224
LNB Power: ON
Press Search Channels
Do you see 91W Nimiq_1?
How is the signal and Quality?
with all those settings and signal 71/quality 85 on 91w nimiq1, still no channels being scanned. i do have 119/110 previously scanned in there if that makes a difference. is there anything more i have to do with the settings?
i did a factory default to start fresh, got signal 75/quality 82 on 91w nimiq1 ku. did a channel scan and still no channels come up on scanning. doesn't make much sense to me. does anydody know what the problem could be? thanks
Username: Plymouth
Post Number: 10054
Mickey
Are you able to lock this satellite?
You must see Nimiq on upper right corner on display.
no, it actually says 110 in the right corner. i never noticed that. what does that mean and how would i fix it? thanks
Username: Plymouth
Post Number: 10062
Mickey
You must turn your dish 11 degree to east and raise a little bit.
Use it for aimed your dish:
http://satcalculator.freehostia.com/
thanks for the info, but i can't see to find that signal. 110 and 119 i can get so easily, but 91 i can't seem to find. i guess i will just keep trying. any other info you can give would be greatly appreciated. thanks
Username: Saqeeb9000
Post Number: 5768
91 is far from 119 , it should be on ur right hand side (depends on location)..
Username: Plymouth
Post Number: 10065
Mikey
Try with Lock Tp 12588
This Tp do have a stronger signal
so if i am in toronto, the dish setup to face west and locked onto 110. how much higher up and do i turn the dish to the left or the right? and by how much approx to hit 91 nimiq1? thanks
Username: Plymouth
Post Number: 10071
Mikey
If you are in back of dish, you turn the LNB arm towards the east, if you look over the dish, turn anticlockwise.
A full rotation is 360 degrees, you must turn 18 degrees.
