New member Username: MukinfutchTN Post Number: 6 Registered: Jun-09 | ive been looking for an amp to power two 2ohm 400w subs. I decided to go with a 2 channel amp but i am stuck on what brands are good for your money. here is one amp i found on ebay. seems awful cheap for suggested wattage http://cgi.ebay.com/US-AMPS-XT-1600-2v2-RE-AUDIO-800W-2-CHAN-CAR-AMPLIFIER_W0QQi temZ350210266629QQcmdZViewItemQQptZCar_Amplifiers?hash=item518a289605&_trksid=p3 286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1234|240%3A1318|301%3A1|293%3A1|294%3A50 |
Silver Member Username: Vivi2000Owosso, Mi Post Number: 204 Registered: Aug-07 | What subs are they and what voicecoil do they have. |
New member Username: MukinfutchTN Post Number: 7 Registered: Jun-09 | kicker compvt's 10'' single voice coil |
Silver Member Username: Vivi2000Owosso, Mi Post Number: 206 Registered: Aug-07 | Are they 4 or 2 ohm? |
New member Username: KipsterDalls, Tx Post Number: 5 Registered: Jun-09 | well let me tell you my friend if your speakers are 2 ohm then a boss 800 watt should be fine. that's of course if you only want to spend about 100 dollars. but if you are looking for quality then find a hifonix 600.1 the reason is because you have 2 single voice coil so you can meke them one ohm. the lower the ohm load the louder it gets. but if you don't like any of those then here is what to look for. make sure if you get a 2 channel amp it's 2 ohm stereo. and if you get a 1 channel it's 1 ohm stable. |
New member Username: MukinfutchTN Post Number: 8 Registered: Jun-09 | ok thanks for your input. ive looked into the hifonics Titan supposedly puts out 750w x 1ohm does anyone own or know about this amp? does it put out suggested wattage? edit: also no one replied about the us amp thats for sale at ebay. There made by Re audio so i expected them to be quality |
New member Username: MukinfutchTN Post Number: 9 Registered: Jun-09 | bump |
