Can anyone help me??? I have a p50 hdtv20a. The problem with it is that when its pluged in the amber light is lite up. when you press the power on button, nothing happens. Any ideas on what to check or what could be the problem.
I have a similar problem with my 50" Vizio Plasma. I can't get it to turn on. Let me know what you find out. I called a TV repairman and he said it's most likely the power unit in the TV and would cost $500 to get fixed. I'm still checking with other sources though.
Has anyone found a fix for this, or know what is causing it. I have a 50 Vizio that is 14 months old and having the same problem. It first happened about 3 months ago and started working all of a sudden. Any help would be greatly appreciated.
