New member Username: Hershey222Post Number: 1 Registered: Jul-09 | So my Subs came today (http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19785) and I went to install them but something puzzled me. 2 Subs and only 1 terminal? So do i run the amp (http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19709) in bridged or no? Just a little confused on how I go about hooking these up. Thanks for the help inadvance. |
Gold Member Username: Drant19DUB-C, TX Post Number: 1807 Registered: Aug-07 | it says that the subs are wired for a 4ohm total impedance, so YES you would bridge the amp. |
