2500 rms amp ???
Username: Jerel_coles
Pennsylvania United states
Post Number: 20
i have a pioneer sub and its rms is 2500 if i get a 2500 watt rms amp will it blow and what kind should i get ?
Username: Ctmike
Ct.
Post Number: 6747
no, and vc and budget?
do you have any electrical upgrades?
Username: Rvpr4
Brampton, Ontario Canada
If the sub is Dual 2 ohm, then you can wire the coils in parallel for a 1 ohm load. Use this amp.
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=1 04&family_id=105&item_id=111751&locale=en_US&p_status=
That's the Rockford Fosgate T25001BD Power Amplifier. It puts out 2500 watts RMS @ 1 ohm. And I think it's underrated too.
Username: Msand951
San jacinto, Ca Usa
Post Number: 121
Or, if its a dual 1 ohm you can wire it to a 2ohm load. Get the ZX 2500.1 mono block. kicker is also under rated.
http://cgi.ebay.com/KICKER-ZX-2500-1-2500-Watt-MONOBLOCK-CAR-AMP-ZX2500-1_W0QQit emZ360166535149QQcmdZViewItemQQptZCar_Amplifiers?hash=item53db992fed&_trksid=p32 86.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1234%7C240%3A1318%7C301%3A1 %7C293%3A1%7C294%3A50
i goy my sister a zx 750 and its pushes her cheap 12"s pretty good with the gain 1/4 way up. but she has cheap pioneers. It will due for now cause she doesnt want to upgrade her electrical. and give up space. She has it on her acura rsx.
Username: Rvpr4
Ontario Canada
Yeah, Mike is right, Kicker is great also,
In my opinion Kicker and Rockford Fosgate are the same;P Fosgate just came to my mind first:P
