Kbox play movies usb?
Username: Legend_killer
Post Number: 219
i want to watch videos on my pc on my tv, i heard u can put them in the usb stick and watch on kbox, but i heard u have to convert it, ummm is there no way i can watch .avi or .mpg videos on kbox?
Username: Saqeeb9000
Post Number: 5661
http://www.squared5.com/svideo/mpeg-streamclip-win.html
ali try this,
i haven't tried this as i have lasonic dvd player which plays all media format.
so give this a try..
Post Number: 220
lasonic dvd player, u mean like that has a usb too?
Username: Brampton_on
Post Number: 42
i doubt it
Post Number: 5662
lasonic hv 670 dvd player,
it plays more format,
it comes with hard disk cassete
so it won't work with external harddrive,
its sort of like this, external harddrive cover with internal harddrive, so u can put the media cassete into lasonic dvd player like u put dvd,
google it u will get more info..
there are other dvd players that some one post long time ago that can do same,
i can't remember them in my head,
this player don't play youtube stuff.
Post Number: 48
Ali let us know if your conversion
to usb played ok on kbox
Post Number: 221
ummm i have an hdtv, and i would like to watch the video to fit perfectly and with black boxes on top and bottom with the screen play in the middle, and not any parts being cut out, what should the video scale size be?
Post Number: 222
also when you play back a recorded video from the usb stick, there is no way to fast forward or rewind.. so you have to play the video from start to end, no browsing for a specific scene or skipping commercials, any help?
Post Number: 5664
so ali did it work?
let me know ,which format did u downloaded,
and did u convert in to ts format,
did u try pic size feature with ur tv remote..
Post Number: 223
ya it did work, i got super converter and a small file converted but the the video on my screen is all stretched and and no black boxes (which i quite like), i think the video scale should be correct.
