Silver Member Username: SnacksQuincy, Florida USA Post Number: 106 Registered: Jul-08 | i have a usb harddrive i believe its 40gb, im not sure if either my computer shut off while updating or if i unplugged it wrong but now it takes like 15 minutes to get the computer to recognize it and i have 2gb ram and it makes it lag so hard as soon as it does. is there anyway i could wipe it or fix it somehow? thanks |
New member Username: CmanxxPost Number: 1 Registered: Nov-08 | I hope I'm doing this correctly. Anyway, I store most of my music on 2 external hard drives. A 500G and a 1000G. Recently I noticed that I am now unable to run my Ipod and the 1000G HD at the same time. Thus making it impossible to load my Ipod without transfering the music to drive c first. The indicator in itunes program freezes up. If I unplug the ipod then th HD will work fine. If I unplug the HD then the ipod will work fine. I have since dumped and reloaded my computer op system (XP home) as I normally do about once a year, but that didn't solve the problem. Is one or the other causing too much of a "load" or something?? This never happened before. Any advice?? Tks//Chris M. |
Bronze Member Username: AymantnPost Number: 15 Registered: Dec-09 | This link may help you http://harddriverestore.blogspot.com |
