New member Username: Alan_pPost Number: 1 Registered: Jun-09 | Lamp light blinks but just changed the lamp 3 months ago. Could it be the ballast and how do you change it? |
New member Username: TvtroublesolutionSan Diego, California USA Post Number: 5 Registered: Jun-09 | Hi Alan, After doing some research here is what I got, A thunderstorm can damage a television specially if there's a lightning strike near your home. The storm can cause sudden spikes in voltage and overheating damaging the electrical components, the power supply (most likely) and the ballast (If power supply is ok) may turn out to be damaged. You can also check these sites for more info on the matter: http://www.fixya.com/support/t2374181-tv_will_not_work http://www.fixyourdlp.com/blog/2007/04/07/how-to-extend-the-life-of-your-dlp-lco s-sxrd-hd-ila-or-lcd-tv-lamp-intuitive-guide/ There is a ballast replacement guide available but for a Samsung TV, this might help you out: http://guides.fixyourdlp.com/samsung/bp47-00033a.php Good luck Alan. |
