Bronze Member Username: Leonard15Post Number: 67 Registered: Oct-05 | I guys up until this week I used my Dish 500 and Viewsat Ex to receive 119 & 110. If I purchased an Nfusion receiver would I still be able to get 119 & 110 again and if so how would I go about getting it up & running. Do I always have to keep it connected to my computer or just to program it? |
Gold Member Username: RiconissanPost Number: 1425 Registered: Feb-09 | Try FTAfiles com I thought you did not "enjoy" this site? |
Platinum Member Username: NydasPost Number: 15369 Registered: Jun-06 | Nfusion has only BEV channels. No Dish channels. For dish channels try kbox (with internationals) or SV ihub (with DN and BEV, but no Internationals) |
Bronze Member Username: Leonard15Post Number: 69 Registered: Oct-05 | Thanks. I didn't say I didn't enjoy this site but I don't enjoy is the extra baggage that goes on when one asks a simple question. All thats needed is a simple answer if one has it or just please ignore the thread nothing more nothing less! |
Gold Member Username: Saqeeb9000Post Number: 5438 Registered: Oct-07 | leonard nfusion is fta rec like sonicview, viewsat, except it has network port, u need to put network cable from ur router to ur rec, u don't need to leave computer on etc, last bin was released in feb or some thing like that, nfusion has bev channel up but no dn yet. wait till next week , dn will be up soon, |
Gold Member Username: Saqeeb9000Post Number: 5439 Registered: Oct-07 | as long as u have internet connection, ur nfusion will be up, but if ur internet is down, u won't be able to watch anything, so its nothing to do with ur computer leaving on,.... |
Bronze Member Username: Leonard15Post Number: 72 Registered: Oct-05 | Thanks Sada very well and professionnaly said. One more question Sada, the computer in my bedroom where my tv is located is not the main internet connection as it gets its internet signal from the router that's hooked up to the main computer in the room across the hall. So I am assuming my TV won't work unless I have a cord long enough to reach the router that's across the hall? |
Bronze Member Username: Your_mamaPost Number: 79 Registered: Sep-07 | you can do wireless |
Gold Member Username: Saqeeb9000Post Number: 5445 Registered: Oct-07 | there is always solution to everything, one member today bought 2 routers today and got it working, although i never tried it this way, but there is definately powerline adapter, best "gadget" ever, no need for messy wires, plug one end in ur router , 2nd one any where in bedroom etc and u have high speed internet, u can definately use if for ur desktop, lets say it is in ur bedroom if u don't wanna see cable wiring etc, also do look at thread k1plus vs nfusion, read what channels, what are u looking for etc, features, etc, i use zyxel ethernet adapter 85 mbps is good speed, http://www.xtek.ca/Powerline-Ethernet-Bridge-85Mbps-One-Pair_p_31-181.html |
Gold Member Username: Saqeeb9000Post Number: 5446 Registered: Oct-07 | also do read this, nfusion is here for long time so yes coder's definately know ups and down for iks, making iks more stable, safer etc, no don't worry about iks being safe, it is safe, tested both nfusion and k1plus this is unbiased information... sada Gold Member Username: Saqeeb9000 Post Number: 4696 Registered: Oct-07 Posted on Monday, April 27, 2009 - 03:09 pm: Edit Post nalin u are welcome and u are right, kbox got few bev channels but nfusion have about 80-90% bev channel if u ignore ppvs and venus.. for nike below is some good info about k1plus.. note this was posted way long ago.. but it gives u some basic idea about the reciever.. for comparison between k1plus and nfusion is that k1plus doesn't have slot for direct ethernet port, nfusion does, with k1plus connects to khub (small device) and then from there it goes to router.. so basically both are same.. k1plus has better pvr /built in usb while nfusion don't .. also pic quality is way awesome on k1plus.. and they also release standalone bins (although nagra 3 is not cracked so there are no stand alone bin in this case. u have to use iks).. sada Gold Member Username: Saqeeb9000 Post Number: 4662 Registered: Oct-07 Posted on Friday, April 17, 2009 - 06:40 pm: Edit Post here is conversation between me and king . sada Gold Member Username: Saqeeb9000 Post Number: 4380 Registered: Oct-07 Posted on Saturday, December 13, 2008 - 10:03 pm: Edit Post nope it doesn't work if u take off sat cable, with nfusion iks is about 98-100% stable, as long as your internet is up, u will be watching channels, as u turno of modem/u loose internet connection, u won't be able to see any channels, true fta channels works without iks,so its no difference than other fta rec other than using iks. that was for nfusion loading the files are simple after f2atv was down, they are just putting the bin in the server, means when u turn off ur rec from back and turn it on, it will say new version is available so u can download it by press ok button, some time when server is really busy u can just use ur laptop, type in ip adreess (that is on ur nf rec) , download the bin and hit the upload button and u will be downloading in secs. 3rd one is old method (note nf nova/sd/) are not built with usb, on kbox its different story k1plus have both option of standalone bin or iks standalone like other fta rec the reason why i don't use iks with k1plus is its not stable , u will see blackscreen/channel freeze,etc with iks so when other rec's are down atleast u can use iks with freezing/etc with dongle i don't have to download any files if i want to , i will still see channels working (if u take out freezing/squeezing) issues] d#n do u mean dn, if u do yes i get both dn and bev channels with nfusion so basically this nfusion has stable iks/ no standalone k1plus has standalone/ freezing problem with iks nfusion is built in ethernet port i think that can be the main reason they have less problem then compare to k1plus } sada Gold Member Username: Saqeeb9000 Post Number: 4381 Registered: Oct-07 Posted on Saturday, December 13, 2008 - 11:31 pm: Edit Post this would be cool device , i am moving to u.s so thinking about something like this, "How often do yo have to load dongle files? - Do yo need dish for yor dongle or does it work like IPTV? " i download file after ecm when new file is around via usb for my k1 plus and use it as standalone (option avialalbe on my k1plus at configration), when there is ecm i simply switch to iks, no need to download file. but b.c of freezing issues with k1 plus i use standalone, when there is no ecm and iks when there is ecm yes same thing with dongle, i need dish in order to make it work both k1plus and nfusion rec needs dish to make them work. no iptv option available on both rec with nfusion its like once a month i barely remember when dish was down and i had to download a new file, most of their files are improvement for example last bin was added b.c it had more bev channels. downloading bin's on nfusion is really low compare to other brand, think like this way bin's are created when ur rec is down, if ur rec is already up, no needs for new bin, https://www.ecoustics.com/electronics/forum/home-video/535576.html here are some stuff about k1plus that i posted way while , for those of you who don't know about k1plus, rocky i don't have 61.5 but i will try to find out which channels are up on 61.5 now with k1plus its way more stable than it used to be, + u don't need to use iks all the time (in this case for new channels they added u must),.. but they still issue standalone fixes.. too.. Top of pagePrevious messageNext messageBottom of page Link to this message sada Gold Member Username: Saqeeb9000 Post Number: 4697 Registered: Oct-07 Posted on Monday, April 27, 2009 - 03:16 pm: Edit Post some more info about the reciever.. reciever was released last year... it was looked similar to koolsat so there was lots of bashing etc with old nfusion home site... it was known as k1hero, at that time, because box was similar to koolsat some koolsat owner bought khub and someone created a file to convert their koolsat6100 to kbox.. so k1plus did what other companies never did before, they ask for to return the box to do the upgrade so that no koolsatowner can switch their box.. they had an excellent customer support, had to pay only oneway shipping, box was upgraded to k1plus (software changed).. now its just k1plus .. now with k1plus what is different than nfusion, it has option of standalone and iks mode, so they release bin after ecm, so after ecm u can swith to standalone if u want to .. or u can stay with iks.. (but with these nagra 3 channels u have to use iks) box had lots of problems at begenning with iks , it wasn't stable, but lots few months things changed they have stabled iks now. now other thing is pvr ,so its built in usb u can record and play to usb/external hard drive.. and pic quality is awesome...} |
Gold Member Username: LolPost Number: 1515 Registered: Sep-06 | sada can a nfusion do non iks ? |
New member Username: DeepamPost Number: 10 Registered: Apr-07 | Some wireless routers won't work with N-fusion please check on nfusion site for compitable routers before buy router. |
Gold Member Username: Saqeeb9000Post Number: 5448 Registered: Oct-07 | paul so for no, with the competition with other boxes, they might think about it, well delvi i think most people have dlink router, etc , but 90% of router do work.. |
Gold Member Username: Saqeeb9000Post Number: 5449 Registered: Oct-07 | Updated list of Routers known to work with nfusion Please find below an updated list of Routers known to work with the nfusion receiver. This list was compiled from data collected directly from nfusion users/owners: __________________________________________________ ________ Apple's Airport Extreme Base Station. AT&T 6800G belkin wireless g belkin wireless n belkin pre-n belkin f5d8233-4 n Belkin Wireless G Model F5D7230-4 (hardwired) Buffalo WHR-HP-G54 D-LINK VWR-vd D-LINK DI-524 D-LINK DI-6041 D-LINK DI-614+ D-LINK DI-624 D-link 625 D-Link Model DL-704 D-LINK DI-704P D-LINK DI-704UP D-LINK DIR655 D-LINK WBR-1310 D-LINK WBR-2310 DYNEX dx-esw5 LaFonera 2 Port Wifi Router LINKSYS BEFSR41 Linksys BEFSR41 ver 4. LINKSYS BEFW11S4 LINKSYS WAP55AG LINKSYS WRT150N LINKSYS WRT300N LINKSYS WRT350N Linksys WRT600N with DDWRT Firmware Linksys wrt54G version 5 router Linksys WRT54G with DDWRT Firmware Linksys wrt54gc Router with Netgear XE-102's LINKSYS WRT54GL V.1.1 Linksys WRT54GL with Tomato FIRMWARE (MLPPP version) Linksys WRT54Gv8 with Netgear XE102's Linksys WRT54Gv8 (set to WAP-2) LINKSYS WRVS4400N Linksys Wireless G Model WCG200 with Netgear XE102's Linksys WCG200 Cable modem and wireless router all in one Linksys WET54G wireless bridge with WRT54G Linksys WET54G wireless bridge with a Dlink 528 wireless router. Linksys Wireless-N Model WRVN4400N Linksys Wireless B 2.4 Model BEFw11S4 Linksys WRT54G router and Linksys Wireless Music Bridge WMB54G using Wpa Personal 2 security. Download new FIRMWARE and software for Bridge first from Linksys site and upgrade before installing bridge. NETGEAR WGR614 NETGEAR WGPS606 NETGEAR WGR614 Netgear Range Max Model WPN824 with Netgear XE-102's Netgear WPGS606 (Bridge) Netgear Wireless Router, Model WNR854T with Netgear XE102's Netgear WGR614 with print server NEXLAND PRO800 TURBO Seimens gigaset se567 modem/router SMC Model WBR14-G. TP-Link Model WR340GD TP-LINK TL-WR 642G wireless Trendnet TEW432TRP Wireless Router WESTELL VERSA LINK 327 WESTELL Model D90-327W30-06 and others................... |
Bronze Member Username: Leonard15Post Number: 75 Registered: Oct-05 | Thanks Sada your 1 of a very few good men on this board. Just to fill you in my main computer is old and has to be the main router link to the internet and the computer in my room is the secondary computer. So can I still hook up the kbox to my computer with it being the secondary 1 or do I have to have the D-link hooked up directly to the receiver? Once again thanks for your patience as I know others on this site are reall bad people and need to be spanked with a whip really hard! |
Bronze Member Username: RunescaperPost Number: 26 Registered: May-09 | i juz bought a nfusion leon knows a bit about sats and stuff..but i dont tell me how to set up like a tutorial plz |
Gold Member Username: Saqeeb9000Post Number: 5466 Registered: Oct-07 | lenord it has nothing to do with computer, u just need to connect with ur router... |
Gold Member Username: Saqeeb9000Post Number: 5470 Registered: Oct-07 | [link removed] nfusion step by step guide, lots of pictures with very good information.. |
Bronze Member Username: DssbssPost Number: 14 Registered: Dec-07 | Not very good lately |
