Nfusion not connecting
Username: Zagros
Post Number: 282
Can anyone tell me what to do about this?
New to nfusion. I am not sure what I am doing wrong, it wont connect. The IP is the same as my pc's IP. I have connected both to the router.
Username: Saqeeb9000
Post Number: 5432
zagros under network connection, change ur mode to dhcp,
i hope u are connected to ur rec via networkcable that goes to ur router and the other end goes to ur rec,
after changing it to dhchp, just reboot the modem and reboot the router...
Username: Zagros
Post Number: 283
Thanks sada;
It is already set to dhcp. I have connected the box to the router also.
Post Number: 5434
zagros only bev channels are working,
so make sure u are on those channels that are working..
check nfusion vs kbox.. thread i posted channel link that is working,
menu, network sw version,swupgrade, download file and let it reboot should work fine,
Username: Zagros
Post Number: 284
I have been trying DN. I will try BEV now.
Username: Zagros
Post Number: 285
It worked. Thanks sada.
