I need help i dont wanna be cheap but i dont want to spend to much i want a good sounding 2 12" subs and amp for my trunk and i dont know very much about all the specfications i know a little bit can you please give me some ideas and help me with this
2) 10" Boss Subwoofers with Diecast Aluminum Frame 1600 Watt Total Power Handling (800 Watt Each) 800 Watt RMS Power Handling: (400 watt Each) Metallic Injection Cone Material Magnet Structure: 140 OZ 2" Aluminum Voice Coil Sensitivity: 94 dB @ 1 Watt/1 Meter 35Hz-2.2khz Frequency Response Impedance: Dual 4 ohms Mounting Depth: 6-1/16" Part Number: SE102DVC 1 Year VM Innovations Warranty
2) 12" Boss Subwoofers with Diecast Aluminum Frame 1600 Watt Total Power Handling (800 Watt Each) 800 Watt RMS Power Handling: (400 watt Each) Metallic Injection Cone Material Magnet Structure: 140 OZ 2" Aluminum Voice Coil Sensitivity: 95 dB @ 1 Watt/1 Meter 28Hz-2khz Frequency Response Impedance: Dual 4 ohms Mounting Depth: 6-11/16" Part Number: SE122DVC 1 Year VM Innovations Warranty
or is this better i personally like this because its 12"
