New member Username: Mittens08Post Number: 2 Registered: Jun-09 | ok so right now i have a American Bass 1080 powering my 2 15inch American Bass DX's. The subs barley flex when there hitting but they still pound soo hard in my car...im thinkin i need a bigger amp but idk its def the loudest system ive had threw 8 dif setups with other 15s and 12s....what do u guys think ne advice is helpful thanks |
Bronze Member Username: Woofers4lifeLexington, Tennessee Post Number: 83 Registered: Mar-09 | whats the RMS for the subs and you budget? |
New member Username: Mittens08Post Number: 3 Registered: Jun-09 | Their only 350 Rms and 700 max..and my budget is prob no more then 250 hopefully |
Bronze Member Username: Woofers4lifeLexington, Tennessee Post Number: 84 Registered: Mar-09 | whats the voice coil configuration |
New member Username: Mittens08Post Number: 4 Registered: Jun-09 | im not exactly sure...my gf got me the subs n box for my bday so idk lol |
Bronze Member Username: D2freakPost Number: 20 Registered: May-09 | hard to tell you what amps to look at without knowing the impedance on the subs, so you can get the most out of your amp |
Bronze Member Username: Woofers4lifeLexington, Tennessee Post Number: 85 Registered: Mar-09 | there single 4 ohm so i would go with a 2 ohm load. http://cgi.ebay.com/New-MA-Audio-700-Watt-RMS-2-1-Channel-Car-Stereo-Amp-NR_W0QQ itemZ380128504341QQcmdZViewItemQQimsxZ20090602?IMSfp=TL090602159002r18057 Thats a cheap one just look around on ebay and other sites if you dont wanna spend alot of money your not gonna get that good of equipment, you get what you pay for. look on here to see what will match with your subs http://www.sonicelectronix.com/viewcat.php?category_id=23&f_163_min=501&f_163_ma x=1000 |
