Opinions on front stage
Username: Drant19
DUB-C, TX
Post Number: 1776
so i got pretty much everything i need for my new system except the front stage... i have 200x2 at 4ohms for power. however, i am confused as h3ll on what to actually get.
Budget: 300ish
ive been lookin at JBL c608
http://www.woofersetc.com/p1182/C608GTi-MKII--JBL-65"-GTi-Component-System.htm
or CDT HDs
or Pioneer c720PRS
or whatever else anyone has any opinions on that would be good.
i need hellp!!!
Username: Deadrabit
Marionville, MO
Post Number: 1911
i like what i got from CDT. not the same but i think everything they make is pretty solid.
the pioneers sound bassy.
never listen to the jbls
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 4153
amp or hu give you the ability to go active?
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6832
jk.. he could always do an external xover.. which wouldn't be a bad idea.. from that list the jbls.. ive been very impressed with install with them. IMO
ive had a few CDT sets.. each one was loud and clean.. but didn't sound accurate.. like a fake reproduction
maybe im just used to my DLS
Username: Rovin
1 15 = 149.5 DBs ...Trinidad & T...
Post Number: 15129
DLS makes some really nice\natural sounding comps
morel & hybrid r also really good products too ....
Username: Drant19
DUB-C, TX
Post Number: 1777
DLS, morel, hybrid...
which actual models out of those brands for my price range???
Username: Frkkevin
Post Number: 6834
You can get the DLS UP6i for a smidge more
check diymobile for some used comp sets.. you'd have more luck on that forum for these that list of comps vs ca.com
http://www.diymobileaudio.com/forum/classifieds/
Username: Frkkevin
Post Number: 6835
UP6i i mentioned was new for that price..
Username: Rovin
Post Number: 15134
ebay has DLS at good prices ...
Username: The_image_dynamic
San Diego, California
Post Number: 5177
The JBL's have alot of the cutting-edge tech that they use in their pro sound drivers and have the best midbass output of any non-exotic comps I have heard. The mid/high accuracy is a little below the higher end models DLS and Focal, which are out of your budget. What the JBL's do excel at is output, which 6 1/2's typically lack, and at $250 shipped from a solid dealer they are easily your best choice.
http://cgi.ebay.com/JBL-C608GTI-MKII-2-WAY-COMPONENT-CAR-SPEAKERS-6-5-NEW_W0QQit emZ130308229283QQcmdZViewItemQQptZCar_Speakers?hash=item1e56f9c8a3&_trksid=p4634 .c0.m14.l1262&_trkparms=%7C301%3A1%7C293%3A1%7C294%3A30
Username: Drant19
DUB-C, TX
Post Number: 1779
they are rated for 150rms... would they handle 175 or even the full 200? i want them to be loud n clear
Username: Frkkevin
Post Number: 6836
yes they will handle more.. make sure its clean power and they are installed right
they are big.. mounting depth is quite a bit.. and again. install is key but in the right install they sound great
play off-axis well
this is why i recommended these to you first.. but im still in love with the dls haha
Username: Armykyle1
Ms Us
Post Number: 690
I was pretty impressed with the D6 and Hex pro comp sets I've heard. The mpyre mids I have are beautiful and I think 200watts would be perfect for them
