OT: FS 4000w Tru Technology SH-1 Sledgehammer ..... and one spoon.
Username: Renegadesrun
Lafayette, IN US
Post Number: 1056
Is this manly enough for you?
I have a Tru Technology sledgehammer for sale in good condition for $1000. Original price was over $3500. There are less than 50 (100 or wtfe, dont care) of these amps in the world, much less in the US. Amp was recently rebuilt/refurbed/repaired (at a cost of around 800) by Tru Technology, and had any issue that could be found repaired/replaced. With exception to a few very minor dings this amp should be considered "as new". Since repair, amp was test run on a 16v system to verify competence of repair work. No less than i expected, ran perfectly. Complete history of amp available via Tru using serials on boards. All future repairs needed can still be done via Tru. Boards built in Korea, hand assembled in the US. Which makes it just as much "US Made" as any Ford, Chevy, or Dodge, without exception. This is a SQ (sound quality) amp that just happens to be extremely powerful. There is one on eBay that is for sale for roughly 2500 right now. Ill take less than half that. This amp is a super clean class A/B, not some POS Class D. She is 7 inches tall by 15 inches long. Pick up in person, bring cash, not BS. For you non locals i will ship upon payment via paypal IF and only if you cover fees involved with that form of payment.
Specs are as follows.
COMMERCIAL GRADE SQ AMPLIFIER/SPL POWER SUPPLY DESIGN
- Very High Voltage/High Current Class AB Mono Block Bass Amplifiers
- Absolute Sound Quality Performance with Tremendous Controlled SPL Output
- C & C Machined Heatsink with Hand Grinded Heatsink Fin Edges
- Constant Rated RMS Power Output until Thermal Shutdown
- High Voltage / Current Unregulated Bi-Polar Power Supply
- +/- 90 Volt Rail Voltage
- 20 ON® TO-3 (250 Volt) Metal Case Output Devices
- 24 I.R.® HEXFET® (60 Amp Rated) Power Inverters for Efficiency
- 4 Hand Wound Power Transformers
- 8 High Speed Rectifier Diodes
- 4 100Volt 6800mf Capacitors
- 2 Pairs Complimentary Transistors for Input Stage
- 4 3 inch Variable speed Intake/Exhaust Fans
- 69.1% Efficiency @ 4 W (Full Power)
- WIMA® Polyproplyne & Mylar Capacitors
- Balanced Line input capability
- Symmetrically mounted heat generating parts
- PROPRIETARY RF Grounding Techniques used for
Improved Reliability and HF noise rejection
- Power section uses Discrete Circuitry throughout Audio Path
- Linkable Amplifiers (H-1)
- 18dB Low Pass X-over (40Hz ~ 300Hz)
- 24dB Subsonic filter (10Hz ~ 100Hz)
- Remote Bass control knob (Optional)
- 4 Gauge Power/Ground Input (2 Sets for SH-1)
- 8 Gauge Speaker Wire Output
- Hand Built in California, U.S.A.
Price: MSRP $3500
SPECIFICATIONS:
Model: SH-1*
Channels: 1 CH
Frequency Response: 10Hz ~ 300KHz ±1dB
Rated Power: 14.4 Volts DC
T.H.D.: < 0.1%
4 Ohm RMS: 2,000W x 1
2 Ohm RMS: 3,000W x 1
1 Ohm RMS: 4,000W x 1
(Burps @ about 6000w for you DB Drag junkies)
S/N Ratio: > 100dB
Input Sensitivity: 0.16mV ~ 4 Volts
Damping Factor: > 700
Efficiency: 69.10%
Fuse Requirement: 120 x2 Amp
Power Supply: 11 ~ 17.9 Volts DC
Low Pass @ 18dB / oct: 40Hz ~ 300Hz
Sub-Sonic @ 24dB: 10Hz ~ 100Hz
Remote Bass Knob: Yes
Bass Boost: No
Dimensions: (L x W x H): 15" x 8 13/16" x 6 3/4"
Weight: 25 lbs. / 11.3 Kg
More pics. http://ampguts.realmofexcursion.com/TRU_SH-1_Sledge_Hammer/
Tru's site. http://www.trutechnology.com/
This is NOT some Sony, Pioneer, Audiobahn, Crunch, HiFonics, overrated piece of crap. This is an extremely high end sound quality amp. If you want a Walmart price, i will give you directions to Walmart. If you want one of the cleanest, best...and arguably ....rarest of the big boys. Ive got just what you need.
Questions? Call/text 765
490 8939
Ill worry about actual pics when someone actually has cash. Same for references. I can provide both.
PS.... will sell spoon for .75c, just to undercut the other dude. :-)
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 4150
arent u a scammmer?
Username: Dlavante
D&L Designs, Daniel Tigard, Or, USA
Post Number: 199
Username: Cozce
St. Louis ILLside, Pronounced: ... U.S.A.
Post Number: 754
I'll have cash when you have pics.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10533
Ren has been on this board forever, hes a good guy
I'll take the spoon, where do I send the .75 :-)
Username: Armykyle1
Ms Us
Post Number: 671
lol spoon, are you copying off me?
Lafayette, IN US
Post Number: 1057
Yes Kyle.
M.S., ill be at your moms. ;-)
JK, YES, i REALLY want less than 1000, but i dont mind fuxxin you guys out of a few extra dolla's.
Cozce, ....email.
Username: Nyyfan13
Northern VA
Post Number: 11476
I would give my left nut for that amp and another RL-s lol.
Tru Tech ftmfw
Username: Cozce
Post Number: 756
I don't really have the cash I just wanted a pic. lol
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 8044
holly sh1t i luv that amp
thats basically two amps strapped togheter.. im pretty sure their the coopper series i forgot the model but still that amp rocks
Username: Loc_out
SoCal
Post Number: 2925
Is this lil rob? You back from mexico?
Post Number: 8045
no dude IM in MEXICO.
hehehe its better overhere man
more money
yes its me
Lafayette, IN US
Post Number: 1058
I take pesos!
Lafayette, IN US
Post Number: 1059
Off to eBay....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D190315119398&ssPageName=A DME:L:LCA:US:1123
No reserve. Good Luck.
Lafayette, IN US
Post Number: 1061
Violated listing policies... oops.
Relisted, ad amended. This time I saw no reference to "talking bad about eBay" in the policy violations so......i did. :-)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT%26item%3 D190315262654
Username: Nd4spd18
Philadelphia, PA
Post Number: 10534
Invalid item
Maybe that wasn't such a good idea
Lafayette, IN US
Post Number: 1062
http://forum.sounddomain.com/ubbthreads.php/ubb/showflat/Number/1664530/page/1#P ost1664530
Cant get link to work from here. Dunno WTF.
Click second posted link.
Better?
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 3448
i'm highest bidder atm
Username: Deadrabit
Marionville, MO
Post Number: 1913
trades?
Lafayette, IN US
Post Number: 1063
Not for car audio! Dont need anything. I kinda got wore out on it.
Username: Nyyfan13
Northern VA
Post Number: 11485
Ren's amount of fail he has exemplified in trying to post the links astound me.
Item number: 190315370845
Username: Hittin1
Post Number: 3452
they pulled your auction
Thanks for your interest in this auction-style listing:
190315262654 - 4000w Tru Technology SH-1 Sledgehammer A/B T0-3 NR!!
Unfortunately, the item is no longer available for purchase. This is disappointing for everyone, but sometimes it's necessary to protect you as a buyer.
There are three main reasons why we remove listings:
-- The listing doesn't follow eBay guidelines.
-- The item isn't allowed on eBay or can only be listed under certain conditions.
-- The listing contains pictures or words in it that may have created copyright or trademark issues.
If the seller is able to fix the problem and relist the item, we hope you'll bid on it again.
We apologize for the inconvenience and have many other great deals on eBay. Just go to http://www.ebay.com to continue your shopping today. We hope to see you soon.
Lafayette, IN US
Post Number: 1064
The amount of BS involved with selling the GD amp astounds me.
This time it was Key Word Spamming in the header. Which violated nothing. I rattled of a scathing email asking WTF, showed them a slimmed down version with absolutely bare minimum of description to find any issue with it....again, they accepted i relisted.
Basically, IMO the guy selling the Sledge for 2500 is pissed that im selling mine at NR which will pull potential buyers from himself. Meanwhile, im sitting here with a amp i worked a week for in trade that i cant fu king sell to get my cash out of due to this b itchmade mf'ers antics.
Scammer/scamming comments are not well received, IRL, or in jest. Since noone is out anything but a few mf'in keystrokes worth of time i dont want to hear any BS. (at one forum or another, over this auction...its gotten old)
Ive sold more sh it on the net than all of you SOB's combined, you can bet on that. Just the first time ive had anywhere near this amount of problems with eGAY.
If you want her, bid, if you dont? Dont. Pretty simple.
My last letter? Says a little more than yours...
Dear renegadesrun (leslie.bradshawATcomcast.net),
You recently listed the following auction-style listing:
Unfortunately, we had to remove your listing because the following information violates our policy:
title: 4000w Tru Technology SH-1 Sledgehammer A/B T0-3 NR!!
Unrelated keywords are those that aren't directly related to the item for sale or that are not relevant when describing the item for sale. Thus, ebay does not permit the use of these words.
wtfe.......
Lafayette, IN US
Post Number: 1066
800 shipped plus 0 to 4 ga connectors, cover PP fees.
Username: Loudon
Post Number: 2972
nice amp ren ... i dont frequent the forum much .. but i remember u from back in the day
wish i had a purpose for it and the funds ...
good luck with the s ale man
Lafayette, IN US
Post Number: 1067
Wish i had the need for her too!
...or the funds.
End result would be the same. Id keep her. Amps like this are few and far between.
Username: Livin_loud
COD4 Addict
Post Number: 2895
that is a piece of excellence right there. i really do want it. i have moneys ready and all... but i don't know what i'm getting for my next vehicle :/ damn temptation of a cr0tch rocket is floatin around in my head as a replacement lol
Diamond Member
Www.stainles... .ecrater.com
Post Number: 20667
Do it.
The bike will only get you in trouble or dead.
Lafayette, IN US
Post Number: 1069
Well, if you change your mind, selling it is an option. This amp has always maintained its value.
Parts are common, Tru can repair indefinitely. Support is excellent. Its definitely a conversational piece that supasses the "wow factor". "Holy sh it",is more the norm. ;-)
Username: Deadrabit
Marionville, MO
Post Number: 1929
ill trade u my rd 1750s for it
Lafayette, IN US
Post Number: 1070
Cant.
Auction will run to term. Happy Bidding!
Username: Jkidder
Post Number: 4158
yea i got confused. sorry guy
Username: Deadrabit
Marionville, MO
Post Number: 1931
what i see doesn't work on ebay
Lafayette, IN US
Post Number: 1071
Dunno why i cant get the link to work from this forum. 3 others, no problems.
Search by my name, its the same everywhere.
OR
Item number 190315370845
OR
Tru Technology Sledgehammer
22 hours left
Diamond Member
Post Number: 20676
Dude you have a fantastic rep on Ebay with a perfect 100% positive feedback score.
Props for that.
Somebody buy this amp already!
