Bronze Member Username: Gboo559Post Number: 42 Registered: Jan-09 | I'm going ported and their site says 3.0@35Hz compact and 4.0@34Hz optimal. What is the difference between compact and optimal? |
Gold Member Username: StnorrisFully Loaded BL 15?, IA US Post Number: 2253 Registered: Apr-06 | compact would be used for more of a compact vehicle due to space restrictions. optimal is the box re is claiming to produce a mixture of the best sound quality and volume available for the sub. this all changes depending on personal preference, how you will use it, and what vehicle it will play in |
Bronze Member Username: Gboo559Post Number: 43 Registered: Jan-09 | Oh well mine is going to be in a trunk. So i should go with 3.0 cu ft? My trunk is pretty big and I'm sure I could fit 4.0 cu ft easy. |
Bronze Member Username: DangerangerOhio United States Post Number: 83 Registered: Mar-09 | If you can fit it and you don't really know your personal preference go with 4 cubes. |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 4140 Registered: Nov-05 | if you live in florida i have several several several 15" boxes you can stop by and test which one you like more and keep it. free |
Bronze Member Username: Gboo559Post Number: 44 Registered: Jan-09 | That's really nice of you but I live no where near Florida lol. I live in California but you think I can buy one off you? |
Gold Member Username: Drant19DUB-C, TX Post Number: 1751 Registered: Aug-07 | go with 4cubes @ 30Hz.. it will murder the lows |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 4142 Registered: Nov-05 | yea no problem send me your email address i'll send you some pics. shipping would be a good bit though since each weighs upwards of 50 lbs. i'll probably only charge about 50 bucks (cost of materials and a little more) plus shipping. these really have no use since i dont own any 15's anymore lol |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 4143 Registered: Nov-05 | i'll also build something custom if you'd like. flared port, aero port, special paintjob, whatever really. i have some free time. |
Bronze Member Username: Gboo559Post Number: 46 Registered: Jan-09 | sent you a PM with my email address waiting for a reply |
