New member Username: Chrisr111Mt.clemens, Michigan USA Post Number: 10 Registered: Jun-09 | what exactly does BP power stand for? |
Bronze Member Username: SundownzMooresville, NC USA Post Number: 55 Registered: Nov-06 | Back Pressure I would guess as the option increases back pressure and directs air across the former (it's a pole plug). |
Bronze Member Username: LoudainteasyPost Number: 26 Registered: Sep-08 | jacob are u the owner of sundown |
Bronze Member Username: SundownzMooresville, NC USA Post Number: 56 Registered: Nov-06 | Yes. |
Bronze Member Username: LoudainteasyPost Number: 27 Registered: Sep-08 | how much power does the 1500 put out my friend had a power acoustik 1500 and it was louder with a direct drop in |
Bronze Member Username: SundownzMooresville, NC USA Post Number: 57 Registered: Nov-06 | Quite a bit : http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7116 I would guess your friend had an installation issue unless you mean the Power Acoustik 5500 model. We have a local SPL organization that clamps power as well (nSPL) and 12v guys average 1500 - 1700 after impedance rise. I've gotten 2500-2600 on 16v as well. |
Bronze Member Username: LoudainteasyPost Number: 28 Registered: Sep-08 | no, its the 1500. wow! the power acoustic amps music be under rated if the sundown1500 does that much power |
Bronze Member Username: SundownzMooresville, NC USA Post Number: 58 Registered: Nov-06 | I'd say either your friends 1500D was broken or set up wrong -- as I am not aware of any 1500D Power Acoustik that does remotely near that power level. What model PA amp ? |
