Bronze Member Username: MikerandPost Number: 12 Registered: May-09 | If I got this amp... http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19264 and this sub.... http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17651 Would this setup work??? Pros? Cons? Thanks! P.S. - Sorry for all the questions...this will be the last one lol. |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20595 Registered: Jun-06 | Ya like Kenwood huh?![]() Building your own box? |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20596 Registered: Jun-06 | Under one of the reviews: "they hit hard hard hard, but break kinda easy. " ![]() |
Bronze Member Username: MikerandPost Number: 14 Registered: May-09 | Yea, Kenwood is a pretty good brand don't u think? and yes I know some of the reviews say that they break kinda easy but my friend has one of these and his has lasted him 2+ years. Nah, I'm not building a box...I'm buying a ported box though... *The reason I made this post is to make sure that this subwoofer and amp are compatible with each other....any answers??? |
Gold Member Username: CtmikeCt. Post Number: 6726 Registered: Feb-06 | compatible, yes. good, no. |
Bronze Member Username: MikerandPost Number: 15 Registered: May-09 | hmmmmmmmmmmm ok.... |
Bronze Member Username: MikerandPost Number: 16 Registered: May-09 | Ok, since you guys think the Kenwood stuff isn't good...disregard my first post. I have changed my mind (once again)...lol I am going to buy this subwoofer. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17852 Which one of these amps would be best? (compatibility and performance wise) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19264 -------------------------------------------------------------------------------- ------------ http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19066 -------------------------------------------------------------------------------- ------------ http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=19346 -------------------------------------------------------------------------------- ------------ Or if you guys have any suggestions within the price range of $100-150 that would be helpful too. Thanks!!!!!!!!!!!} |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20599 Registered: Jun-06 | Don't get my response wrong. You made a great match up. That amp will power that sub "as designed". If it fits your budget then run with it. It's just Kenwood is not ranked as an upper end equipment supplier. At least as far as underground standards go. Hell I ran 2 12" Kenwoods years ago in my own box and loved them Then again that was 10 years ago. ![]() |
Gold Member Username: Drant19DUB-C, TX Post Number: 1752 Registered: Aug-07 | how about you give us a budget man... |
Bronze Member Username: MikerandPost Number: 19 Registered: May-09 | $300-350 is my budget. For everything (Sub + Amp + Wiring + Ported Box) |
Gold Member Username: Safe_crackerFcking H0M0S , Wear FipFlops!! US Post Number: 4940 Registered: Jan-06 | Stay away from mainstream stuff (sh!t you buy from the store) and try to buy something used but in good shape from a reputable seller on a forum. You will have a chance to grab something 1/2 way decent maybe save some more money.... JMHO.. Polo.. |
Bronze Member Username: MikerandPost Number: 20 Registered: May-09 | I'm really not trying to spend anymore than 350$...its my first system and I just want a cheaper setup that still hits hard...u know wat im sayin... |
Gold Member Username: Safe_crackerFcking H0M0S , Wear FipFlops!! US Post Number: 4941 Registered: Jan-06 | Stay away from mainstream stuff (sh!t you buy from the store) and try to buy something used but in good shape from a reputable seller on a forum. You will have a chance to grab something 1/2 way decent maybe save some more money.... JMHO.. Polo.. |
Bronze Member Username: MikerandPost Number: 21 Registered: May-09 | I'm really not trying to spend anymore than 350$, I'm in college so I don't really have or want to spend more money than that....its my first system and I just want a cheaper setup that still hits hard...u know wat im sayin... |
Bronze Member Username: DangerangerOhio United States Post Number: 87 Registered: Mar-09 | do you care about sound quality at all or are you just trying to get loud? also do you have any friends or know anyone good with woodworking? 9 times out of 10 it will make it sound better if you don't use a prefab box. |
Bronze Member Username: MikerandPost Number: 22 Registered: May-09 | I'm really just trying to get loud. Like I still care about SQ but I'm more interested in loudness... |
Bronze Member Username: MikerandPost Number: 24 Registered: May-09 | I'm really just trying to get loud. Like I still care about SQ but I'm more interested in loudness... |
