can i connect my pansat to my pc through USB 2.0 to 9 pin RS232 COM Port Serial Adapter?? i have windows vista and i want to connect pansat 2700a to it.. can i use this cable or which cable i can get?? thanks
Yes, that's exactly how I load my Pansat 2700a., with Vista. Works well, you just have to try changing the port settings until you find which one works, mine works on port 4. Good luck with yours.
