Spl amps
Username: Purplehase_bong
BC Canada
Post Number: 335
theres an amp locally i can get for dirt cheap. just wondering what you guys think and if i should buy it.
specs are
Output power (14.4V) : Class - D (MONO)
Into 4 Ohms : 800W x 1
Into 2 Ohms : 1500W x 1
Into 1 Ohms : 2800W x 1
Linkable at 2 Ohms : 4800W x 1
Frequency Response : 20Hz ~ 330Hz
S/N Ratio : > 90dB
T.H.D : < 0.03 %
Input Sense : 300mV - 8V
Variable Bass Boost : 0~+18dB at 45Hz
Username: Drant19
DUB-C, TX
Post Number: 1750
those number could be impressive or overrated...whats the actual amp model? (ie. Sundown 1000d, mmats 3500.05, etc.)
Username: Deadrabit
Marionville, MO
Post Number: 1861
what amp is it?
BC Canada
Post Number: 336
sierra spl 4800.1 Monoblock D class
http://www.sierracaraudio.com/2005_product_sra4800d.html
Username: Safe_cracker
Only Fcking H0M0S , Say WaterPolo! US
Post Number: 4939
A class D amp typically has a THD of around 1% the .03% THD gets me thinking... BS..
Polo.
Username: Carguy
Post Number: 6960
How much is the amp? If you go by the spec alone, they should be charging you $2000 - $3000.
Don't get sold on numbers. Take a look at Pyramid amps. They will promise you the moon for $100. Read the fine print on their website.
BC Canada
Post Number: 337
275cad, warehouse lasts. I'm going to take a look tonight
