Need help with my future setup. Help Please...
Username: Mikerand
Post Number: 12
If I got this amp...
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19264
and this sub....
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17651
Would this setup work???
Pros?
Cons?
Thanks!
P.S. - Sorry for all the questions...this will be the last one lol.
Diamond Member
Www.stainles... .ecrater.com
Post Number: 20595
Ya like Kenwood huh?
Building your own box?
Diamond Member
Post Number: 20596
Under one of the reviews:
"they hit hard hard hard, but break kinda easy. "
Username: Mikerand
Post Number: 14
Yea, Kenwood is a pretty good brand don't u think?
and yes I know some of the reviews say that they break kinda easy but my friend has one of these and his has lasted him 2+ years.
Nah, I'm not building a box...I'm buying a ported box though...
*The reason I made this post is to make sure that this subwoofer and amp are compatible with each other....any answers???
Username: Ctmike
Ct.
Post Number: 6726
compatible, yes.
good, no.
Username: Mikerand
Post Number: 15
hmmmmmmmmmmm ok....
Username: Mikerand
Post Number: 16
Ok, since you guys think the Kenwood stuff isn't good...disregard my first post. I have changed my mind (once again)...lol
I am going to buy this subwoofer.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17852
Which one of these amps would be best?
(compatibility and performance wise)
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19066
http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=19346
Or if you guys have any suggestions within the price range of $100-150
that would be helpful too.
Thanks!!!!!!!!!!!}
Diamond Member
Post Number: 20599
Don't get my response wrong. You made a great match up. That amp will power that sub "as designed".
If it fits your budget then run with it.
It's just Kenwood is not ranked as an upper end equipment supplier. At least as far as underground standards go. Hell I ran 2 12" Kenwoods years ago in my own box and loved them
Then again that was 10 years ago.
Username: Drant19
DUB-C, TX
Post Number: 1752
how about you give us a budget man...
Username: Mikerand
Post Number: 19
$300-350 is my budget. For everything
(Sub + Amp + Wiring + Ported Box)
Username: Safe_cracker
Fcking H0M0S , Wear FipFlops!! US
Post Number: 4940
Stay away from mainstream stuff (sh!t you buy from the store) and try to buy something used but in good shape from a reputable seller on a forum. You will have a chance to grab something 1/2 way decent maybe save some more money.... JMHO..
Polo..
Username: Mikerand
Post Number: 20
I'm really not trying to spend anymore than 350$...its my first system and I just want a cheaper setup that still hits hard...u know wat im sayin...
Post Number: 4941
Polo..
Username: Mikerand
Post Number: 21
I'm really not trying to spend anymore than 350$, I'm in college so I don't really have or want to spend more money than that....its my first system and I just want a cheaper setup that still hits hard...u know wat im sayin...
Username: Dangeranger
Ohio United States
Post Number: 87
do you care about sound quality at all or are you just trying to get loud? also do you have any friends or know anyone good with woodworking? 9 times out of 10 it will make it sound better if you don't use a prefab box.
Username: Mikerand
Post Number: 22
I'm really just trying to get loud. Like I still care about SQ but I'm more interested in loudness...
Username: Mikerand
Post Number: 24
