SoundDeadenerShowdown.com
Username: Skibum12189
Cleveland
Post Number: 3188
wasn't this site supposed to be the sh!t. I feel like they changed the whole structure since the last time i visited. Last time i went on it, it was so informative. Am I on the wrong site? What did they determine was the BEST edead/dynamat/etc? Was it fatmat or one of the like 20 others i forget their names?
Username: Bernymac
Phnom PenhCambodia
Post Number: 4650
Yeah the site did change from the last time i visited it as well. From what I remember, raamat was the best in terms of price/performance. But this was years ago. Some products have changed. More companies using butyl instead of the asphalt based material.
Username: Cozce
St. Louis ILLside, Pronounced: ... U.S.A.
Post Number: 749
http://web.archive.org/web/20080208080514/www.sounddeadenershowdown.com/conclusi on/
Username: Sundownz
Mooresville, NC USA
Post Number: 46
He came out with his own line and took down the old information.
Cleveland
Post Number: 3189
is there a "best" deadener right now? I am only buying a little so I don't mind paying a lot for it. raammat is still real good stuff right?
Username: Denim
SoundSolutionsAudio.com, MD USA
Post Number: 866
After years of doing testing and providing free results to the masses, Don learned a great deal about deadener and decided to make his own. The price of SDS products are very good and so far, every customer I have talked to has loved it.
Username: Sundownz
Mooresville, NC USA
Post Number: 53
My testing on Second Skin Pro went very well :
http://www.sundownaudio.com/misc/96_Jeep/deadener/Log/
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2987
I used cheap eDead and it worked perfectly lol
Cleveland
Post Number: 3190
very cool write up jacob. I have a 2000 cherokee so that was perfect. was the hatch hard to deaden? how much did you use? does it still stay open with the stock liftgate holders.
Username: Sundownz
Mooresville, NC USA
Post Number: 54
Yes - the hatch stays open fine. It was not incredibly difficult to do either. I only used one layer - just a couple of sheets of Damplifier Pro.
Honestly - I didn't gain any SPL so I quit with one layer BUT it did take down the rattles alot in that area!
Cleveland
Post Number: 3191
yea the trunk rattles like crazy
Username: Basebalz13
Moneta, Va Usa
Post Number: 1587
he concluded that raamat was the bst for the money, but the best hands down, price doesnt matter was Second Skin Damp pro
jacob has seen a large DB gain for such a little thing to do and so have I.
I saw a 1+ DB gain just from sound deading :-) not to mention having a rattle proof 150+
Username: Hdubb
Team Revolution
Post Number: 4147
ive played with a few deadeners....edead ue,edead v.1^2,dynamat extreme,damplifier pro, older raamat stuff (not bxt) asphault based. the edead stuff was usless in my install. the ue was just as bad as the v1^2. :-( dynamat extreme is a very good deadener. if gotten at a good price well worth it. second skin damplifier pro IS the BEST deadener i have used. ive gained roughly 1.9 db from installing it on my roof,doors and ext cab area. the raamat actually suprised me. it seemed thin and maluable, but when i layed it down it did much better then i thought. if i had to choose, it would be damp pro, or dynamat extreme.
Moneta, Va Usa
Post Number: 1591
x2 hunter ive played with most of those, but just thought id leave it to... SS damp pro be all end all deadner
