Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7495 Registered: Mar-04 | Guy came by the shop and wanted a box for his old school kicker subs, but they were kinda in rough shape. Seemed to be sagging and surrounds are not in the best shape. He also had a MMATS 100hc to drive them. Well, here are some build pics: Everything other than the floor is 1.5" thick, baffle is cross braced w/ 4" Mdf strips. |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7496 Registered: Mar-04 | 3 cans of spray-glue and 2 razor blades latter... 18cuft, 34hz |
Bronze Member Username: DangerangerOhio United States Post Number: 81 Registered: Mar-09 | that's a pretty beefy box. Did you get to hear them? |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7497 Registered: Mar-04 | He is coming next wednesday for the install. |
Platinum Member Username: Rovin1 15 = 149.5 DBs ...Trinidad & T... Post Number: 15064 Registered: Jul-05 | i bet that shiz is damn heavy with that double layer i like how u braced between the subs do meter it b4 it goes looks excellent ! ... |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20578 Registered: Jun-06 | With that much effort/cost I would have tried talking him into new subs as well. It DOES look great though. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1851 Registered: Jun-07 | the subs closer to the port looks like they don't have room with the port and braces. it looks like a 2 inch gap but it might just be the angle u took the pic. looks good though |
Silver Member Username: WickedbassNashville, Tn Post Number: 639 Registered: Jan-08 | Looks good man. I wanna see some more pics of the install when its done. |
Platinum Member Username: InsearchofbassPost Number: 11589 Registered: Jun-04 | Thats a nice box Canaan. |
Gold Member Username: DuckaHoughton and/or Macomb, MI United States Post Number: 1036 Registered: Jan-08 |
I think Canaan knows a thing or two about box building. https://www.ecoustics.com/electronics/forum/car-audio/572724.html |
Gold Member Username: Tatonka-[Team Audible Insanity]- Post Number: 2979 Registered: Mar-07 |
Wow, I never thought you would chime in with your opinion. Have you took a peek at your 17 threads about your build? You are about as loud as most peoples two 10s setup. |
